What the
is a "voltage eliminator"? You mean AC-DC power supply? Notebook AC adapter?
If it is pulling that much, probably you made a short circuit somewhere. Did you put your multimeter in series with the load, not in paralel?
yes its an AC adapter from a printer i dont have anymore, sorry in my country we call them voltage eliminators so i just translated it and it came out like that, i just noticed that, i might edit my post
the multimetter is in series with the load at the positive lead after getting rectified
I also meassured before the rectification, the ac adapter its pulling only 1.19 A from the main line (outlet) and after getting rectified its giving 4.40 A kind of expected since all of this its in the label (3.42)
however im pulling 30% more current than the ac adapter says it can give, also its getting hotter (65c-90c) so it worries me a bit,
The other possibility, is that the LED strip is rated 220mA per segment, about 3-4 LED per segment (small strip). And you put 15-20 there.
I do believe this since for example aht the roof i have 3 strips each with 25 segments of 3 leds the
the leds get to 30c-35c, but the ac adapter its what worries me the most,
I already tried using 2A adapters and leds just keep blinking, im assuming because they need more current
