Hey all,
I'm using
this TTL oscillator, specifically the MXO45-3C-5M0000.
It seems simple enough. So, I get out my benchtop power supply, set to 5VDC, and a breadboard.
- Pin 1 is on the lower left, looking down at the package. That's the enable pin, so hook it to +VCC.
- Pin 14 on the upper left is power, hook to +VCC.
- Pin 7 on the lower right is GND, hook to GND.
- Pin 8 is the output, connect to oscilloscope.
Power up with 5VDC, get... 20Hz out. WAT.
Replace, try another one. Get... 150Hz. WAT!
Okay. Clearly there's something I don't know about this thing. Does anyone have an idea what I'm doing wrong?
