Author Topic: Which terminal of this old FROLYT electrolytic capacitor is which?  (Read 5751 times)
Offline Whales
    • Halestrom
I've been trying to repair one of my father's old tube radios.  One of its problems is a 50hz hum, which I would presume is caused by the main filter capacitor:
I don't have a clue which end is negative and which is positive.  There are the numbers '1' and '2' on the bottom terminals of the cap and the (German?) writing translates to something approximately like 'negative pole is the case'.
I'm having difficulty identifying the polarity from the circuit: in the ratsnest I think it uses valve rectifiers.  For all I know this may be a double electrolytic/non polarised cap  :D
Can anyone point me in the right direction?
« Last Edit: December 25, 2015, 11:17:02 pm by Whales »
Online mikerj
Re: Which terminal of this old FROLYT electrolytic capacitor is which?
« Reply #1 on: December 25, 2015, 11:24:20 pm »
The way the capacitance is stated gives the answer (50+50uF); it contains two 50uF caps with a common negative connection to the case.
Online wraper
  • Country: lv
« Reply #2 on: December 25, 2015, 11:25:35 pm »
This is dual cap. Both terminals in the center are "+" for each of them, case is common "-" for both of them.
Offline Whales
    • Halestrom
« Reply #3 on: December 25, 2015, 11:32:55 pm »
Thanks wraper and mikerj.  This explains why they went to the effort of a large spring washer for mounting it to the chassis: the case needed to be connected.
Offline MickM
« Reply #4 on: December 25, 2015, 11:56:37 pm »
If you want to keep the same look, no big open holes, you can "re-stuff" that can.
Open it up and put two new caps in there.
In Bob's video the cap is not the same style as yours, but it might be close.
I subscribe to his channel, mostly 1930+ radios and 40s-50s TV sets.
Mick M
« Reply #5 on: December 26, 2015, 08:21:17 am »
Replace with 2 47uF 450V electrolytics, which probably will be 105c versions as that is the most common, and they will be radial. You probably will be able to fit them under the chassis, and because they are low ESR you want to connect a 10R 1W resistor in series with the positive leads, so that you do not blow up the valve rectifier from the current pulses, as the old ones would have an ESR in that range in any case.
Online wraper
  • Country: lv
« Reply #6 on: December 26, 2015, 02:22:53 pm »
Doubt this is necessary, Most likely there are 100+ ohm series resistors anyway if valve rectifiers are used.
« Reply #7 on: December 26, 2015, 03:08:44 pm »
10R resistors if direct from the rectifier, just to take off that sharp current spike which heats up the anodes so much. Second stage not really needed, as there will be either a choke or a dropper resistor there. Kind of belts and braces only.
Online wraper
  • Country: lv
« Reply #8 on: December 26, 2015, 03:28:13 pm »
I mean there already should be a resistor between rectifier and cap. If there is not, circuit is crap.
« Reply #9 on: December 26, 2015, 03:58:42 pm »
Many did rely on the resistance of the transformer secondary and the ESR of the capacitor to limit anode current. Replace the rectifier with a silicon diode and you need the resistors, otherwise you risk blowing up capacitors and the transformer from those new higher peaks.
Offline Whales
    • Halestrom
« Reply #10 on: December 28, 2015, 10:10:47 am »
I can't find any resistors, but I will add a couple of 10R when replacing the caps.  I've heard about this before and was surprised not to find any.
« Last Edit: December 28, 2015, 10:16:04 am by Whales »
