Yes, definitely a 100n capacitor to ground on the THR/TRG line, and maybe a series resistor before it too (1k?), otherwise it's effectively an open antenna for spikes.
Edit: Does that capacitor on the CON pin work reliably for defining the power-up state? It might be rather sensitive to slow power supply rise time. The more usual method would be an RC network on the Reset pin.
