Author Topic: Dual 3.3V, 5V, 12V power supply modules for workbench  (Read 736 times)
Offline suspensionTopic starter
« on: August 26, 2024, 05:52:10 pm »
Hello
I usually work with many projects simultaneously and having a low voltage power distribution along my workbench (which is around 20 feet long) for standard voltages is very convenient. The required voltages are +-5V, +-3.3, +-12V. Having other voltages such as 1.8, 2.5 is also helpful but not absolutely necessary. My plan is to have multiple power ports fixed to the workbench at various places each outputting a standard set of voltages.
I can use standard bench power supplies for this setup, but this would require 6 of them which is too expensive. I am looking for much lower cost alternative. The currents need not be high as 99% of the time these will be used to power digital circuits. Ideally cheap power modules that can output 2-5A at these voltages will work. For example modules that use chips such as LM2596. However in order to create + and - voltages, I should be able to connect them in series. The LM2596 based ones cannot be connected in series.
What other options are there? Also like to hear about other ways of achieving the same. Please note ATX power supplies will not work as they do not seem to have -5 and -3.3V voltages.
Thanks
s
Offline rstofer
Re: Dual 3.3V, 5V, 12V power supply modules for workbench
« Reply #1 on: August 26, 2024, 06:17:16 pm »
One way might be to just run +5V and use Digilent PowerBRICKS for the other voltages:
https://digilent.com/shop/powerbricks-breadboardable-dual-output-usb-power-supplies/
These are made to mount to a solderless breadboard so you may have to adapt the mounting.
Murata make some nice DC-DC converters with multiple outputs.  +-15V is handy for op amps.  Search Digikey
https://www.digikey.com/
Online mariush
« Reply #2 on: August 26, 2024, 08:17:03 pm »
I think that's a bit bad idea, because the longer the wires the more voltage drop you're gonna have. If you put the "low voltage power distribution" somewhere along the desk length, you may end up with 5-10 feet of wires between the sockets and the project you're working on.
Make yourself a few small boxes with a barrel jack for DC input  and a LM317 / LM337 pair.  You can use a MC34063 to create a negative voltage from the positive voltage ... for example -18v from 16-20v input then use LM337 to make -15v.
Or maybe just buy a transformer with two 15v secondary windings, add a bridge rectifier and a couple capacitors and you have your +/- 18v-ish DC.
You could use a slide switch to select between +/- 3.3v , +/- 5v, +/-12v , +/- 15v   or +/- adjustable (add two 10 turn pots or something like that)
With the right slide switch you could also switch the feedback resistance for the mc34063 as a sort of tracking (ex if you want -5v, then convert 16-20v to -7.5v instead of -18v)
Online thm_w
  • Non-expert
« Reply #3 on: August 26, 2024, 10:47:40 pm »
Probably have two main +12/-12V AC to DC converters, then those rails go across the whole bench. Its very easy to find 12V 5A or 10A supplies.
Then buck or linear regulate each side down as needed with commonly available modules.
The thing I don't like with this is the lack of current limiting and monitoring.
« Reply #4 on: August 27, 2024, 08:38:39 am »
Thank you all for valuable suggestions. While looking for MC34063  based modules as suggested by mariush, I was able to find few modules in AliExpress that fulfills my requirements:
https://www.aliexpress.com/item/1005005269336203.html?spm=a2g0o.order_list.order_list_main.12.264f18026R6Pz8
https://www.aliexpress.com/item/1005005510092848.html?spm=a2g0o.order_list.order_list_main.17.264f18026R6Pz8
Online mariush
« Reply #5 on: August 27, 2024, 11:28:10 am »
You can get reasonably cheap brand name power supplies that output positive and negative voltage from places like Digikey, for example : https://www.digikey.com/short/w842m82w
Offline alexk195
« Reply #6 on: October 01, 2024, 02:50:02 pm »
Hi. Im currently finalizing my power supply here www.el08.de/pps1. But it has no negative voltages and is not isolated. Do you need also higher amps on negative voltages? I suppose it's for amplifiers?
Online Randy222
« Reply #7 on: October 01, 2024, 05:20:13 pm »
mains to 24vac xfrmr (toriod perhaps), bridge recitify, caps for filter, maybe a coil to take out EMI, and then just parralel some linear voltage regs (pos and neg) to get as many regulated outputs as you want, perhaps making one of then adjustable with a dial pot. Obviously the amps would be limited to the xfrmr ability.
Offline Gribo
« Reply #8 on: October 01, 2024, 06:19:33 pm »
Get a long DIN rail, mount it to the wall or the back plate of the bench and then get some DIN rail AC to DC power supplies. They start at ~40$. As an added bonus, you can also mount other types of DIN modules - anything from a relay board to a PC.
I am available for freelance work.
Offline Smokey
  • Not An Expert
« Reply #9 on: October 01, 2024, 08:28:17 pm »
I'm imagining an engineer running back and forth along a 20ft bench frantically tweaking pots on tons of boards all hooked up at once..  when one changes it effects all the others...  I think I've had that nightmare actually.
