Hey all,
I ran into something confusing I can't quite figure out.
After finding this section in a schematic
where a single capacitor R224 and R225 is only connected to ground, with both its legs. These parts surround U200, the magnetic sensor, as can be seen in the foto
, where we see a crystal oscillator top left, then top-mid the sensor (U200) and top right R225 and R224. With the missing capacitor (why is it even labeled R?) one can also very clearly see it's the ground traces being connected.
This photo is from iFixit, where R225 seems to have been broken off. On my board, R224 is broken off. The picture does show it was broken. Not sure if this was during repair at some point, or they do this in the factory.
But first, I need to understand what the purpose is/could be. What's even more weird, the part is specced as 1207. Measuring it seems to be somewhat around 1.3 mm * 0.72 mm. The width seems to be spot on, where the length can be explained by the tin on the sides? Anyway, I measured R225, as I lack R224. I ordered a cap of the right value as a 1608, so slightly bigger, but does it matter?
