Author Topic: why did mfrs stop placing parts vertically on PCBs??  (Read 1790 times)
Offline jauntyTopic starter
« on: February 04, 2020, 12:37:39 am »
i'm curious as to why after the mid 1970s manufacturer's stopped doing things like mounting resistors and diodes perpendicular to the circuit board. Anyone know about this? seems after that point you'd ONLY see them mounted flat on their through-holes. Was there an issue with parasitic inductance? parts acting like little aerials and picking up strayEMF? Cost and labour (since they had to insulate the leads and it's likely a BIT more work to place the parts? or pick and place machines needing flat mount parts?
inquiring minds want to know
Online coppice
Re: why did mfrs stop placing parts vertically on PCBs??
« Reply #1 on: February 04, 2020, 01:01:01 am »
vertical mounting reduces the board area, allowing for a cheaper PCB, and makes the whole structure more 3D. This tends to suit packaging requirements better than having large low profile boards. However, vertical mounting makes things less robust. You need to ensure that knocked components don't short or break their leads. I guess you are seeing a crossover point where robust reliable results outweighed the benefits vertical mounting brings.
The following users thanked this post: jaunty
Offline Conrad Hoffman
    • The Messy Basement
« Reply #2 on: February 04, 2020, 02:08:23 am »
We still mount vertically at times- when the SMT resistors and caps "tombstone" by accident!  :-DD
The following users thanked this post: jaunty, EEEnthusiast
Offline Bud
« Reply #3 on: February 04, 2020, 03:00:25 am »
Most likely has to do with moving to automated assembly from manual one.
Online coppice
« Reply #4 on: February 04, 2020, 10:06:19 am »
Board stuffing machines deal with horizontal and vertical mounting. I don't know if tthere are different defect rates for the two orientations, but they both generally work OK.
Offline nfmax
« Reply #5 on: February 04, 2020, 10:10:13 am »
I don't think they have stopped - you still see this in 'live-chassis' mains thingies, like fan timers, PIR light switches, etc.
Offline Ian.M
« Reply #6 on: February 04, 2020, 11:42:23 am »
I think a lot of vertical mounting of axial components went away when SMD became dominant.  That certainly wasn't mid 70's, that's far too early unless you are thinking about Cordwood construction.
Offline ogden
  • Country: lv
« Reply #7 on: February 04, 2020, 12:03:00 pm »
Vertical mounting is still there, especially in low cost AC/DC power supplies & modules:
https://www.eevblog.com/forum/buysellwanted/acdc-adapters-12v-4-16a-50w-earth-referenced/
« Reply #8 on: February 07, 2020, 09:15:06 am »
alright well thanks - i just haven't seen it since working on mid-70s boards - if you look at audio equipment for example - i work on synthesizers, pro audio and stereo stuff sometimes and it seems ubiquitous and reaching 'peak' levels maybe mid 70s or so and by the 80s on the same kind of equipment i'm seeing all 'flat' componentry
Offline poorchava
  • Troll Cave Electronics!
« Reply #9 on: February 07, 2020, 02:20:27 pm »
Vertical THT is still very much a production thing. When manufacturing in less that 1k unit batches (= when manual stuffing and other manual operations are a thing) this is a common thing to do (in our company anyway, but we do some EMS and clients' designs albo have vertical axial components).
Offline ArthurDent
« Reply #10 on: February 08, 2020, 02:56:03 pm »
Here is a photo of a brand new RD6006 power supply module. You can see that there are a lot of flat (surface mount) components but there are also parts mounted vertically on the board where it made sense. The inductors, filter caps, and one big blue resistor are sticking up to save space. If these were laying flat against the board it would have to be much larger as others have pointed out.
Offline HwAoRrDk
« Reply #11 on: February 08, 2020, 04:09:05 pm »
Speaking of caps, that seems to be one area where the trend has reversed. Axial electrolytic caps used to be fairly common, but you hardly ever see them used nowadays.
Online coppice
« Reply #12 on: February 08, 2020, 04:17:50 pm »
Axial electrolytics have only ever been common for smaller parts. I think you are looking at SMD designs, where all the small axial electrolytics have migrated to SMD packages, and the through hole electrolytics are large radial ones. If you look at designs which are still fully through hole I suspect you'll find as many axial electrolytics as in previous decades.
