No, you were exactly right. It is mechanical, not electronic. It’s got nothing to do with solder joints. The effect in question is (erroneously!) called “stiction”, but it’s actually lubricant failure. Freezing causes tolerances to change just enough to allow the platter to spin up.
Sorry, totally wrong. It’s lubricant failure in the platter bearings. Nothing to do with electronics failure.
the drive spins
What I'm still trying to figure out is how tooki knew without a shadow of doubt that lubricant failure was the cause.
If the bearings are failing, why is the drive losing files?
