why would I ignore advice from an article because it contains a word like "guitar"?
besides, engineers make mistakes too, for example how RCA tube manuals recommended a heater wiring that connects to the power transformer at one end for one wire, and the other for the other wire, for more equal voltage across the tubes, but it creates an incredible hum loop.
Why would you need the screen to be an unvarying set DC voltage, that is almost never needed, and also a sturdy screen supply would most likely melt the screen if you drive the tube too hard.
the only problem I see with bypassing the screen to the cathode is reduced gain, and perhaps it could in the rare occasion cause problems when the screen behavior inverts and you get positive feedback, but I doubt this would ever happen in a normal circuit...
Out of interest, I Googled for "Mullard Amplifiers", & found this:-
https://archive.org/details/19400164MullardCircuitsForAudioAmplifiers/mode/1up?view=theaterLooking through it, I found they
do return the screen bypass to the cathode, but it seems to be only in EF86 input stages where the tube is operated with very high value anode & screen resistors in what they term the "starvation" mode, combined with a split cathode resistor with a bypassed part around 1K
& an unbypassed section of around 100
, with negative feedback from the secondary of the amplifier's output transformer applied across the latter.
Ck in all instances is around 50uF---much larger than shown in the "valve wizard's" example.
In each instance where this is done, DC coupling of the EF86 anode to the grid of the following phase splitter is also used.
In other, more conventional EF86 stages, the screen bypass is directly returned to ground.
Unfortunately, Mullard don't go further into why they sometimes do this, & sometimes not.
As to a "sturdy screen voltage"--in high power Tetrode RF stages, the screen supply is regulated, so it has no adverse effects, seeing many such stages are driven at very high levels.
The only time the screen will be damaged is if the anode voltage is lost entirely, & the screen voltage is still present.
Variations of anode voltage with signal levels will not cause excessive screen current.
I was brought up in the valve era, I even built the 3 watt amplifier shown in the Mullard book.
Much of my work life was involved with "hollow state" devices---in Radio & TV Broadcasting, the "valve era" hung on a long time!
