Author Topic: This LTSpice model for TL431 is bonkers  (Read 2477 times)
Offline iMo
  • Country: li
Re: This LTSpice model for TL431 is bonkers
« Reply #25 on: December 26, 2024, 01:38:26 pm »
https://www.eevblog.com/forum/eda/ltspice24-importing-the-a_bordodynovs-lib-and-examples/msg5761125/#msg5761125
Everything in the LTspice is in its original state after the AB install based on my guide.
Nothing there has been "replaced"..
The AB lib has been "added" to the existing original libs..
Offline Zero999
  • 0999
« Reply #26 on: December 26, 2024, 02:42:37 pm »
To improve portability and ease of use. I extracted the .asc files from TL431.ZIP, pasted Eugene's model into them and replaced all of the custom symbols with RH1009.asy. You can now simply copy and paste them to the schematic, which saves the need for multiple files.
Offline KonkedoutTopic starter
« Reply #27 on: December 26, 2024, 05:40:44 pm »
* TL431 Eugene Dvoskin model.asc (3.84 kB - downloaded 5 times.)
Thanks.  That one does seem to work.
FWIW I have 3 times tried to download Bordodynov's 20M zip file.  Even waiting > 30 minutes with good high speed internet, my laptop always gets stuck with an "Unconfirmed XXXXX.crdownload".
So the signal-to-noise ratio out there is not so great....   :(
