It should work as a summing amplifier.
I don't think that particular circuit values are correct however. I think they're just copying AP5724 circuit (which is correct within reason), correctly scaling the sense resistor for 20mA full scale load current, but forgot to scale control voltage injection resistor (R3, and/or R2) to 0-2V control voltage.
Thanks! This helped me figure out how to analyze the circuit. Now if I can only remember my fundamentals...
The feedback (FB) pin internal difference amplifier's reference voltage is 0.31V (nom.). That means the current regulation loop acts to keep FB close to that voltage swinging above and below it slightly with every cycle of the internal switch. The datasheet tells up the formula for the average LED current (no dimming) is If=0.31V/Rset.
By injecting current at the FB pin, you can fool the control loop that the LED current is higher than it actually is, thus reducing the LED current. However its at an inconveniently low impedance, requiring a control current equal to the max. LED current, so R2 is added so the control current is reduced by a factor of 1+ R2/Rset. Thus to fully extinguish the LEDs, Ictl_max=0.31V/(R2+Rset), and R3 scales that to the desired upper limit of the control voltage input range.
However I think there may be an error in the datasheet's maths (and thus the R3 resistor value I proposed earlier, which I scaled from theirs)! It states that "For VDC range from 0V to 2V, the selection of resistors in Figure 3 gives dimming control of LED current from 0mA to 20mA." which is patently absurd as Max. VDC gives min. If and visa versa. Also the potential divider R3:(R2+Rset) is wrong - we know it must develop 0.31V at FB when If=0. Neglecting Rset as its three orders of magnitude smaller than the potential divider resistance, the fig 3 resistors give VFB=VDC/21 which is a max. control voltage of ~6.1V.
Sorry, I think I'm doing something really stupid. So you said that to fully extinguish the LEDs:
So if I plug in 5k for R
2 and 15 ohms for R
set, then the max control current is 6.18 * 10^-5 Amps? Is this supposed to be the same as the max LED current (20 mAmps)? I don't think I'm doing it right.
I'm also confused about how exactly R
3 scales the current...
In the meantime, I tried to find a relationship between V
DC and I
SET by solving the op amp and surrounding circuit. I'm getting lost in the middle and not sure if this is the right direction...
Labeling the diagram like so:
I can try and do the node voltage calculation for V
N, like this guys does:
https://electronics.stackexchange.com/questions/156719/opamp-inverting-amplifier-the-case-of-non-inverting-input-not-being-connected-tI assume V
N is equal to V
REF. I get the same answer by solving for V
SET:
This is where I'm stuck. I think I need to figure out the relationship between V
DC and I
SET, and I have this hunch that I
SET is I
LED + I
CTL... And that I'm missing an equation or two to figure out the relationship between I
LED and I
CTL.
And
then I guess plug in numbers for V
DC and I
CTL to decide which values to use for R2/R3?
