Also 6BG6 (sweep version), 807 (coke bottle, RF), 1614 (metal, RF), etc.
Mind that new "6L6s" are all over the place, at least in the cheaper brands. Everyone makes 6L6GCs, because of course they do, but they don't all handle 30W like a 6L6GC is supposed to. Derate generously (say 30-50% below rated), treat them more like 6L6GBs if that.
Even then, the material quality is poor, so don't expect great lifetime.
That's a nice advantage to industrial and PQ types: better materials, higher ratings, longer life. A $100 tube that lasts 10khr is a better deal than a $50 tube that lasts less than 5k -- assuming you have the budget to do so, and will be using the equipment frequently.
Or conversely, if not, it may actually be a better deal to use the cheaper part, and then maybe keep spares handy, accepting that when (not if) the originals fail, you'll have the annoyance of changing them out, but you won't be SOL for a week awaiting delivery of new parts.
One last thing. Mind that poorly constructed tubes are more likely to melt or arc over and fail shorted. Have some protection method in place (a crowbar?) to deal with this. It's most likely to happen at the lowest output voltages, where the load will be most vulnerable to a surge to full B+...
