Hello,
I'm developing a 134kHz HDX (frequency modulation) RFID reader which must be able to read spiral tags like the one in the picture.
I'm using EM4095 reader IC. The antenna is 1.5mH and is also of solenoid type because I figure it's the only way to read a tag like the one in the picture which is aligned in parallel with my reader antenna.
The space inside is free air, length 65mm, diameter 15mm.
My reading range is 4cm which is bad ,but good enough for my application. To be honest, I don't have a clue how to get a better reading range with a tag of this size? What's the optimal antenna diameter if tag diamater is cca 3mm? From my measurements, bigger diameter antenna has a better range.
The problem is that I have to enclose the antenna in a thermoplastic potting case (Polyoxymethylene (POM) or polyacetal) and then fill two component polyurethane resin inside. When I do that my reading range drops TWO TIMES
First, the frequency changes from 134 to about 124kHz, but I offset this by tuning the frequency to 144 before potting. The problem is even when the frequency is 134 or close, my reading rage is lower than before potting.
When I enclose the antenna in the potting box, reading range falls from 4cm to 3cm even without potting?
Here are my questions:
1) Why does the frequency change? I know that 10kHz RLC metar does not see a frequency change, but 100kHz meter reads 10kHz drop. It confuses me because both thermoplastic and resin are not magnetic materials, i.e. their permeability is close to 1 like air.
2) Even with the frequency good, the reading range is much lower. Why?!
If you can give me any clue of what to investigate I would be grateful.
Thanks.
