Did not think about cooling but with the existing tubes, the LUX starts at 1000 when they are "cold" (room temperature) and increases to 1800 after around 5-8 mins warm up time. This took me time to discover on double sided boards, why was one side so much better exposed than the other...
Regarding the intensity, I believe the 6*8W tubes are quite strong, and even then, I need like 8-9 mins exposure times. I do not particularly want to be waiting 20 minutes per PCB side, that is why I was thinking will the light be adequate?
