Author Topic: Why NMOS for buck switchers? (other than generally better NMOS specs)  (Read 1115 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
Just reading up on switchers... Assuming a basic circuit, with a catch-diode and a pass transistor: The buck circuit examples I have seen all use an NMOS with drain @Vdd, and Source tied to the inductor, hence a possible difficulty driving the NMOS gate fully ON for smaller Vin-Vout.
I wondered - if I invert the sense of the drive signal, can I use a PMOS, with Source at Vin+, drain tied to inductor? Ominously, I cannot find any examples :-\, must be a catch...maybe to do with impedance of D Vs S?
(In my case I'd like a high current, but pretty low voltage difference (say 3v), between Vin and Vout, hence (for the NMOS solution) I'd need to find an NMOS with low Vto)
Online Kleinstein
Re: Why NMOS for buck switchers? (other than generally better NMOS specs)
« Reply #1 on: August 09, 2019, 01:53:31 pm »
One could use a P_MOSFET, but as already written, PMOS performance is not as good.
One a chip it is often cheaper to use NMOS and bootstrapped gate drive. It usually requites 1-2 external caps.  This also gives better performance.
The following users thanked this post: 741
« Reply #2 on: August 09, 2019, 02:03:43 pm »
Many thanks for your explanation - my mind is "easier" now.
It seems to work OK in LTSpice.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 09, 2019, 02:30:07 pm »
They're out there:
https://www.ti.com/lit/ds/symlink/tps40200-q1.pdf
Performance is king.  The difference is not small -- PMOS is about 2.5x worse than NMOS.  More die area = bigger package and more cost (with knock-on costs from lower production quantities -- i.e., PMOS in general are less common, and cost more as a result).  Poorer Qg*Rds(on) figure of merit = generally higher switching losses, and either higher conduction losses or higher drive losses (drive power is Qg * Vgs(on) * Fsw).
You need a driver anyway -- the gate has generous capacitance in either type, so a mere logic-level output is unsuitable for all but the smallest transistors -- and it's not much added die area (if integrated) or cost (if discrete*) to include the bootstrap driver for NMOS.  So it's very practical to use NMOS in high or low side application. :-+
* "RTL" level discrete that is, i.e., using ICs for basic functions.  Low side, logic-input drivers are cheap and plentiful (TC4427, etc.), as are bootstrap drivers (IR2110, etc.).  If you're doing something truly discrete (bare transistors), it's harder -- a high-voltage, noise-immune level shifter is certainly doable, but it will take more transistors than the alternative (compare this (first page, top and left half) to this, for example).
Seven Transistor Labs, LLC
« Reply #4 on: August 11, 2019, 01:14:42 pm »
Hi Tim
"Gate_Driver.png" reminded me of something I saw in a textbook ("circuits for electronic instrumentation", T H O'Dell, p103).
For added drive on fast edges, the top-left transistor had an emitter decoupling capacitor, also both bases of left-side transistors were tied via a capacitor.
Offline T3sl4co1l
« Reply #5 on: August 11, 2019, 01:52:19 pm »
Yup; you would need a resistor in series with the diodes (probably replace one diode with a resistor of equivalent voltage drop) to allow some "emphasis" to be coupled through a capacitor.  A downside of this connection is, significant supply ripple (more than a modest fraction of Vbe, say) is coupled from the high side to the low side, through the capacitor, potentially causing erratic operation and shoot-through.  So you need to use good bypassing, and to separate or shield the supply from induced fields (fields can be quite intense in a big inverter circuit).
