Sure, the SoC has fast interfaces. How do you access this without hacking the tablet?
hacking = opening the case, unplugging the camera, plugging own cable.
Hacking the tablet is going to be particular to one type of tablets, and cheap tablets tend to come and go, so it's hard to standardize on one type unless you pick an expensive type like a Samsung/Apple product. Are you also proposing to build your own tablet?
It needs to be done once per device, not the biggest hurdle. USB 3.0 enabled tablets will be here in a year.
All of that is front end. Community build a family of frontends, starting with cheap ass 2x20MHz and see what software people can do with it.
Many SDRs don't even have 20 MHz bandwidth, let alone dual channels. Most SDRs use USB 2.0, which can't sustain 2x20 MHz on a single port. So what components would scopes and SDRs have in common?
dsp, software components are already build and tested in open source SDR applications (some even GPU accelerated).
Its pretty obvious I wasnt talking about reusing SDR hardware.
You already can. Any DSO sold today can interface with a computer over USB and/or LAN. Often with a well-documented SCPI protocol if you buy a decent brand.
Yes, they let you download small sample window, or preprocessed data, or like AndyC_772 says crappy web interface with laggy javascript net 2.0 joke of a UI.
Few people use this for general purpose use (as opposed to logging or automated setups) because it's a pain compared to the stand-alone scope and software availability is poor. Is either of that going to change when an open-source scope comes along? Look at the Sigrok project: none of their GUI's offer a decent interface for a logic analyzer yet. None of the GUI's for the open-source SUMP/OLS logic analyzer is that great either. And the GUI for a LA is much simpler than for a scope.
scope has broader usage scenario than logic analyzer so there is a chance more people would work on it. Look at gnuradio or Gqrx for example, difference between fixed function hi-end ham radio and even cheap SDR + open source software is like night and day. It doesnt have to be like sigrok or Gimp
So how about taking that decent hardware that you're not going to exceed in either performance or price in an open-source design and replace that shitty software?
You would still have to pay for 2/3 of the box (fpga/soc/lcd) that you never use in case of using frontend/adc and connecting to a tablet/pc. Reusing whole thing is too difficult (as mentioned before in the thread), reverse engineering custom design would limit brain power to few determined hackers versus people who know dsp and can program pc.
In general it seems that you guys are looking to increase the number of challenges, as if reaching your core target is not hard enough. Summarizing your and Marco's post together it seems that you guys want to build an analog front-end, an active probe, the ADC + digital hardware, build/hack a tablet and write software better than that by Owon/Hantek/Atten/Rigol. Each of which alone could easily take an experienced engineer a few months of work, depending on how high you're aiming. If you want to accomplish something, then you should identify the core problem you're trying to solve and focus on that.
Best case scenario would be reusing/copying whole frontend up to ADC, and building only PC interface.
Lets face it, writing better software than Owon/Hantek is a given, you cant go worse than that
I think you've got your market and price points a bit confused. $1000 is what you'd have to pay for serial decoding on the better quality bench scopes, not the Owons of this world.
Yes, owons of this world usually dont even offer most of the interesting decoders, or responsive UI for that matter
You're getting a very polished, fast, responsive and reliable UI on that level of scope, which you'll struggle to match on a PC. The limitations you describe really only apply to the very bottom tier.
Highend scoper _are_ x86 PCs.
