Author Topic: Why use an N channel MOSFET to connect GND  (Read 1398 times)
Offline ilium007Topic starter
« on: March 10, 2019, 01:22:48 am »
Hi - I came across this Freescale MC33926 breakout from Pololu and found this in the schematic. The numerous GND pins on the SMD package are connected to GND via an N channel MOSFET triggered by Vin. I am wondering why these pins aren't just tied direct to a GND plane on the PCB ?
I am starting out with electronics design and wondered why the designer may have chosen to go this way ?
Offline tsman
Re: Why use an N channel MOSFET to connect GND
« Reply #1 on: March 10, 2019, 01:26:55 am »
The carrier board has a reverse-protection MOSFET for added protection to the motor driver chip.
The following users thanked this post: NiHaoMike
Offline retrolefty
« Reply #2 on: March 10, 2019, 02:47:22 am »
I suspect it's to properly sequence powering up to prevent glitches on the output drivers.
Offline bson
« Reply #3 on: March 10, 2019, 03:03:56 am »
Note that the source pin is on the top and drain on the bottom, and it connects GND to Earth/Chassis.
Offline Mr.B
« Reply #4 on: March 10, 2019, 03:05:11 am »
This...^
Offline georges80
« Reply #5 on: March 10, 2019, 03:10:15 am »
http://www.ti.com/lit/an/slva139/slva139.pdf
Been using these schemes for years now for reverse polarity protection. Minimal voltage drop compared to using a diode (even a schottky).
The zener is needed if the gate voltage would otherwise be too high (depends on the supply rails).
cheers,
george.
Online NiHaoMike
    • Facebook Page
« Reply #6 on: March 10, 2019, 03:14:52 am »
The part that trips most beginners up is that MOSFETs can conduct in both directions when turned on. And in fact, will do so better than a diode - look up "synchronous rectification" as well as the poorly named "ideal diode".
Here's a video explaining different options of reverse polarity protection:
« Reply #7 on: March 10, 2019, 04:59:26 am »
Thanks for all the replies. I have another weeks worth of reading to do !
