Author Topic: Has anyone seen a goose neck hot air station for microscope work  (Read 1663 times)
Online PsiTopic starter
Has anyone seen a goose neck hot air station for microscope work available to buy?
(By 'goose neck' i mean like those positionable microscope lights.)
So you can place a PCB under the microscope and the goose neck is pointing hot air at the center of the microscope view.
Maybe 100-150C.
Then when you use your soldering iron to remove a part it's easier because the goose neck hot air is preheating the board area you're working on.
« Last Edit: March 04, 2023, 01:54:17 am by Psi »
Online BrianHG
Re: Has anyone seen a goose neck hot air station for microscope work
« Reply #1 on: March 04, 2023, 04:24:42 am »
I built my own.
I found a cheap microphone gooseneck holder with a heavy stand at a local surplus store.
I cut off the mic and added a heavy C clamp on it's end.
The C clamp was large enough to hold my hot air station gun.
Online BrianHG
« Reply #2 on: March 04, 2023, 04:31:37 am »
Why not just buy one or two from Aliexpress?
God know how many they have there...
1
2
3
4
5
All of them...
« Last Edit: March 04, 2023, 04:34:03 am by BrianHG »
« Reply #3 on: March 04, 2023, 05:34:27 am »
1
2
3
4
5
All of them...
The hot air gun and it's air hose are pretty heavy, I doubt a normal goose neck clip like those cheap ones would be able to hold it up reliably.
Online BrianHG
« Reply #4 on: March 04, 2023, 05:49:06 am »
Funny, my hot air gun weighs just under a pound, or 0.5kg.  No problem holding that.
Also, if you looked at the search, there were even goose necks designed to hold tablet PCs/ I-pads.
Are you telling me your hot air gun is that heavy?
You begun wanting to buy a new hot air gun in the first place which used a goose neck.  What do you think it would have used.
Just buy the ones with a visibly thick segmented metal goose-neck for 5$-15$ and give it a try.
The shorter ones are really stiff and strong able to support at least 1 pound.
Also, you can search for desktop boom microphone holders as the have screw locked rigid arms, but the 1-3 foot goose neck will most likely offer the greatest flexibility.
« Reply #5 on: March 04, 2023, 06:28:20 am »
its not so much about the weight of the hand piece but the weight of the hose that hangs from the hand piece.
The leverage of that means it will always try to twist a goose neck unless its super robust.
(The air comes from the box, not generated in the handle.)
Online timeandfrequency
« Reply #6 on: March 04, 2023, 09:21:42 am »
Please show us a picture of your hot air gun.
The WELLER hot air iron HAP 200 weights less than 200g (0.4 lb) : the air compressor is also in the station, not in the handle.
Strong goosenecks. Different lenghts & diameters.
I would not preheat the PCB with hot air. Try this one for under the PCB and the smaller one above the board.
A temperature PID controller with SCR (= TRIAC, Phase-Shift Trigger) output. Ask the vendor if the triac is internal or if t has to be wired externally. A temp sensor will also be required.
« Last Edit: March 04, 2023, 09:39:34 am by timeandfrequency »
« Reply #7 on: March 04, 2023, 10:14:25 am »
its just an Aoyue 968 A+, nothing special.
But the point is a hose hanging off the side creates a huge torque on any joint because it acts like a weight on a large lever.
A strong goose neck should work if the attachment on the end doesn't have a ball joint.
but any cheap plastic aliexpress one wont have a chance
« Last Edit: March 04, 2023, 11:09:49 am by Psi »
Offline wraper
  • Country: lv
« Reply #8 on: March 04, 2023, 10:39:51 am »
Do not reinvent the wheel and use normal preheater under PCB.
« Reply #9 on: March 04, 2023, 11:08:35 am »
I have a Puhui T8280 preheater already, but it is not always the best tool for the job.
Heating up the entire PCB using the preheater takes a lot longer than just soldering a part with the iron.
Pointing the hot air gun at the general area while using the iron prevents quite a bit of heat being pulled away from the join into the surrounding area. It turns a 9 second job into a 3 second job
Offline wraper
  • Country: lv
« Reply #10 on: March 04, 2023, 11:10:13 am »
Hot air type like 853 works much faster for smaller areas.
« Reply #11 on: March 04, 2023, 11:15:25 am »
If i replace my hot air it will be with a Atten ST-862D.
I'm not a fan of the kind that have the blower fan inside the handle.
That being said, perhaps i could purchase just the handle piece from one like that, Then i can permanently mount it to the side of the microscope on a goose neck and run the power cable along the side of the microscope.
That might work well
« Last Edit: March 04, 2023, 11:17:52 am by Psi »
Offline wraper
  • Country: lv
« Reply #12 on: March 04, 2023, 11:28:26 am »
I meant hot air preheater.
Offline ajb
« Reply #13 on: March 04, 2023, 07:52:04 pm »
I have a couple of these in different sizes that work well for this sort of thing: https://www.amazon.com/gp/product/B09FT6T34G/
They're the same basic idea as the Noga style indicator arms, except that these have a toothed interface at the elbow joint to provide positive locking and prevent it from sagging.  The included clamp works well for hot air guns at a range of sizes.
« Reply #14 on: March 04, 2023, 08:17:59 pm »
What about PCB heating from above with a 15W NIR laser source ?
[update #1 : gun -> source]
« Last Edit: March 08, 2023, 03:28:50 am by timeandfrequency »
Offline thm_w
  • Non-expert
« Reply #15 on: March 07, 2023, 12:34:12 am »
Yes, this is what I do too.
But for actual soldering so I don't need to hold the wand while removing/installing an IC, almost never use it for preheating. Hot air preheaters in general are not great. A decent IR unit is relatively cheap, <$150.
20" is a good length for this. Then there is the 10" smallrig branded model, which is very high quality, but too short.
« Last Edit: March 07, 2023, 12:35:46 am by thm_w »
Offline ajb
« Reply #16 on: March 07, 2023, 08:54:25 pm »
Heh, I see you also use a piece of extrusion on the bench as a mounting point, that's been on my to-do list for a while!
