Hum, first page has this:
B. Jacobs*#1, J. W. Odendaal#2, J. Joubert#3
*SAAB Avitronics, Antennas Group
185 Witch Hazel Avenue, Centurion, South Africa
1bennie.jacobs@za.saabgroup.com
# Centre for Electromagnetism, Department of Electric, Electronic and Computer Engineering, University of Pretoria,
Pretoria 0042, South-Africa
2wimpie.odendaal@up.ac.za
3jjoubert@postino.up.ac.za
Here is the refs:
K. L. Walton and V. C. Sundberg, “Broadband ridged horn design,”
Microwave J., pp. 96–101, 1964.
[2] S. Hopfer, “The Design of Ridged Waveguides,” IRE Trans.
Microwave Theory and Techniques, vol 3, no. 5, pp. 20-29, 1955.
[3] J. L. Kerr, “Short axial length broad-band horns,” IEEE Trans.
Antennas Propagat., vol. 21, no. 5, pp. 710–714, 1973.
[4] C. Bruns, P. Leuchtmann, and R. Vahldieck, “Analysis and Simulation
of a 1-18-GHz broadband double-ridged horn antenna,” IEEE Trans.
Electromagn. Compat., vol. 45, no. 1, pp. 55–60, 2003.
[5] ——, “Comprehensive analysis and simulation of a 1-18 GHz
broadband parabolic reflector horn antenna system,” IEEE Trans.
Antennas Propagat., vol. 51, no. 6, pp. 1418–1422, 2003.
[6] ——, “Full wave analysis and experimental verification of a broad
band ridged horn antenna system with parabolic reflector,” IEEE
Antennas and Propagation Soc. Int. Symp. 2001, vol. 4, 2001.
[7] M. Abbas-Azimi, F. Arazm, and J. Rashed-Mohassel, “Sensitivity
analysis of a 1 to 18 GHz broadband DRGH antenna,” IEEE Antennas
and Propagation Society Int. Symp. 2006, pp. 3129–3132, 2006.
[8] M. Botello-Perez, H. Jardon-Aguilar, and I. G. Ruiz, “Design and
Simulation of a 1 to 14 GHz Broadband Electromagnetic Compatibility
DRGH Antenna,” 2nd Int. Conf. Electrical and Electronics
Engineering, pp. 118–121, 2005.
[9] V. Rodriguez, “New broadband EMC double-ridged guide horn
antenna,” RF Design, pp. 44–47, 2004.
[10] M. Abbas-Azimi, F. Arazm, J. Rashed-Mohassel, and R. Faraji-Dana,
“Design and optimization of a new 1-18 GHz double ridged guide horn
antenna,” J. of Electromagn. Waves and Appl., Vol 21, No. 4, pp. 501–
516, 2007.
[11] EM Software & Systems, FEKO User’s Manual, Suite 5.4, July 2008.
Perhaps request a PDF from the authors? I can view it but not download it. :-) See if your local library has a program called "interlibarary loan" ?
Basically all it says is that small gaps of 0.5 to .005 inch on the ridges and edges of the planar pieces induce deep but very narrow spikes of low response in assembled antennas on the production line. They found that the overall gain pattern was fine, but these narrow spectral regions moved around each time the assembly was bolted together. They also found the depth of teflon dielectric on the feed was critical. They modeled it in a modeler called FEKO and determined which tolarences were sensitive to errors. Basically gave them a bad notch at 14 Ghz.
They then modeled the back box that does the coupling and found out it was very sensitive to small changes in placement and dimensions, especially the teflon covered probe. Specifically the placement of the probe.
Moral of the story, build an accurate back box for coupling, or make it adjustable in position, or add tuning flaps/screws.
They do not give plans for the antenna. The horn was screwed together, not soldered, so gaps would matter. When it was bad, it was NOT that bad. Just a major dip at 14 Ghz.
------------------breaking news------------------------------------
SEE IF YOU CAN SEE THIS, 1-10 GHZ.....
http://deepblue.lib.umich.edu/bitstream/handle/2027.42/4877/bac2123.0001.001.pdf?sequence=5&isAllowed=y
Deep Blue usually allows public access... HAS COMPLETE DRAWINGS FOR A SIMPLE RIDGED HORN 1-10 GHZ !!! Steve
