the frequency response of all systems tends to zero as the frequency increases.
What does that mean?
Take a sinewave and drive it into a series combination of a resistor and a capacitor. Measure the output across the capacitor. As you increase the frequency, the response of this network, i.e. output relative to input, will decrease. Ultimately, at infinity frequency the output would be zero.
But you'll not find an infinite frequency oscillator because all real systems have the equivalent of series resistance and capacitance to ground. The resistor dissipates energy on each cycle, therefore, to get infinite frequency would require infinite energy. The same is true for any real system (electrical, mechanical, whatever,...). The response always tends to zero as the frequency increases.
I simulated the circuit with a gain higher than 3, and the frequency decreased (even though it was very close to a square wave). You claimed that the frequency would decrease based on the energy argument you presented. I am still confused for two reasons:
1. Why doesn't the output look sinusoidal when the gain via the resistors increases, why is it sinusoidal?
2. You claimed that energy/gain/frequency are functions of each other. Can you clarify what you mean?
1. The magic value of 3 comes from the R-C bridge network. To compensate for this loss, the "amplifier" is given a gain of three. If you were to break into the amplifier-R-C loop you would find that the overall loop gain would be unity. Anything less and the oscillations die away anything more and the oscillations build up until the signal saturates, i.e. the circuit becomes non-linear, and therefore non-sinusoidal. While in its linear region, you can consider the R-C network is attached to a perfect amplifier with a gain of 3, then solve the differential equations for the Rs and Cs.
2. I think I've explained the energy-frequency thing above. I think I may have been a bit confusing when talking about gain (that's the problem with multiple loops!) I was thinking about it this way: The overall gain of the loop varies, downward, for a frequency shift in either direction (due to the R-C network). Due to the energy considerations, it's "easier" for the amplifier if the frequency shifts down rather than up. Although, I 'm willing to listen to any more solid arguments
