I have looked at the pdf files that the seller have on the LED strip and the mini controller, and that seem to bring some clarity, but some issues arise.
@Audioguru again
Yes, I am fairly certain I will make use of the color changing feature of this LED. What I don't know for sure, is if I will like it or not, but at least I get to tune both the brightness AND color, at the push of a button, being a toggle. What I am trying to find out, is if I can get to easily adjust all these things without opening the lamp cover, would be nice if there were buttons or knows accessible to the user right outside the lamp within arms reach.
@tmadness
I will see what I can do about making a schematic soon. (Sketch uploaded below) Btw, I only need about 1.9 meters of LED strip, not the whole 5 meters. I detest wifi, but I could accept an infrared controller. I also don't have a modern mobile phone to control stuff with. A set of buttons and knobs/dials would be idea imo.
What I learned:
The LED strip:- 2000 --> 6500K (color change)
- dimmable from 100% --> 0%
- 2A max power
- max 48W effect for the whole strip of 5m, 9,6W/m, or about 18W for 1,9m
- installation of LED requires soldering on the three wires at one end of the LED strip
- seller writes "Tunable white is change of color temperature at 100% brightness"
The mini controller: (I thought this had an optional push button, but it seems now that the "turn knob" on the device is just a push button, so there is no turn knob on the mini controller as I initially thought:
- Has one button, with three modes, controlled by a hidden jumper: 1) toggle BETWEEN preset cool white + bright light AND preset warm white + reduced brightness 2) adjust brightness 3) adjust color
- contact holes on mini controller on both ends fits AWG 22-26 wires
- fed with + & - supply voltage, two wires
- outputs + & WW (warm white?) & W (white?)
- default installation, appear to have a three pin jumper hidden in lamp, and potentially one push button that could be extended outside the lamp cover to become easily accessible.
- functionality seems limited to pressing the one button, and also by moving the jumper around, pressing the same button to set max values for its dim2warm function, specifically brightness and color, the button push enabled the dim2warm function BUt also requires the jumper to be set that way as well. Seems like suitable for a set-once type of lighting, with a one button cool white/warm white toggle. I would want to figure out if I can add some controls on top of this that is accessible through the lamp cover.
- Manual says "maintaining mains reversal" I don't know what that means, so maybe device is not acting like a diode? I thoguth I had learned that diodes only works with the electricity going one way.
- Max 2,5A per channel
- Max 75W, at 30V
- Outputs voltage from 12-30V
- Input voltage from 12-30V, depends on LED to be used
- customer support acknowledged to me now that this mini controller canont both dim the LEDs and also enable the dim2warm function, so it only does 1 of three modes depending on what position the jumper is set
Aluminium profile w. plastic transluscent cover:3cm diameter, circular in cross section, part alu profile, part plastic cover. Space for 11 mm wide LED strip.
Goals: Having a nice LED desk lamp, that has tweakable controls accessible at the outside of the white lamp cover. The powersupply can be under the desk. I think I know how I could rig this all up to get the lights going, but it is still a mystery how to get to have buttons, dials or turn knobs for tweaking: on/off button, dimming knob (can't be a toggle), color change knob/button (I can accept a toggle for the color, between a cool white and warm white)
Safety aspect: I also want your feedback on this issue. Supposedly, this lamp would have fixtures and a 1m long metal rod on each side that is to conduct the power from the power supply up to the lamp standing 1m above the desk surface. Would a 1m steel or brass rod really conduct electricity? Or, is maybe there supposed to be a hidden wire there at the center. I thought the rods were solid, but maybe I am wrong abou that. I guess I can try check if that is the case.
Would be nice if I could maybe have the mini controller and the LED strip connected in a serie on the alu profile, and then maybe add a turn knob for generall dimming on the lamp BEFORE the mini controller if that is possible. Optionally also, an on/off button BEFORE the mini controller. An accessible dimmer is a must, as I don't want to risk start sweating with this LED lamp some 40cm above my head at the desk.Here are links to product pdf files from seller if you trust opening such files in these days:
LED strip:
https://www.ledrise.eu/amfile/file/download/file_id/26051/product_id/1144/ (From:
https://www.ledrise.eu/led-strips-modules/tunable-white-96-110w-1396lm-m-nichia-performer-led-strip-140-nichia-leds-m-24v-price-5-meters.html)
Mini controller:
https://www.ledrise.eu/amfile/file/download/file_id/26939/product_id/1028/ (From:
https://www.ledrise.eu/led-drivers-transformers-and-accesories/tunable-white-mini-power-control-unit-dimming-and-special-mode-sku-51162.html)
Q: I wonder if I could maybe have two mini controllers in a serie before the LED strip. Then, I would at least get to have one additional push button. Unsure if that would simply work. Button #1 (toggle cool vs warm light Button) #2 (dim light by keep pressing the button down).
Update: I have sent an email to the seller asking if I can set up two controllers this way, one button for toggle color, and one button for adjusting brightness.
Update: Hm, I guess it would make sense that (ref images below) the "W" connection on the LED strip is for brightness only. WW being connection for light color. OR.. one connection goes to one of the two LEDs (paired) and the other one goes to the other LED (same pair).
Update: Maybe the best location to add a turn knob for "brightness" could be right before the LED strip, connecting that to the "W" connection (presumalbly for brightness). That way I could use only one mini controller to set a permanent color toggle (button). Having this other added turn knob for brightness. And then, maybe an on/off button at the very start of the series of components here inside the lamp (I could drill a hole in the plastic cover, to access on/off switch AND the mini controller button AND the turn knob for brightness.
Update: I added a third drawing, showing only one mini controller for setting a fixed toggle for color, and adding a potentiometer just before the LED strip to control brightness (I guess, it would only control the cool white LED, and perhaps not both LEDs in the pairs)
Update: I guess what I have drawn on my drawing, is a rheostat, with two connections and not a regular potentiometer. But maybe a pot can be used as a rheostat?
Although the manual says that both led's can be on 100% (double the wattage for nearly a 19W in total per meter, don't know that that is enabled), I don't know if both LEDs in the pairs, are supposed to be on regardless of color temperature chosen. Presumably cool white would have the darker and more yellow in the pair light up with less or no power. I wish I knew more about this. I guess I can ask the seller again, if they aren't tired of my emails by now.
Added: I have at least a candidate for a dimmer, rated 5A, which should be well enough, expecting no more than some 40W tops (ca 1,7A). Hm, can't have that thing dangling around, must be placed in a box then, if added as suggested by seller, after the powersupply, near the desk surface somewhere. I guess encasing plastic ought not be flammable styrene (something I could make), or maybe that doesn't matter too much.
Presumably material choice matters, to make it robust, and perhaps non-flammable, not sure.
https://www.ledrise.eu/led-drivers-transformers-and-accesories/led-dimmer-pwm-v2-12-24vdc-max-5a-sku-50975-01.html
