Author Topic: Getting LCD panels in low quantity  (Read 2891 times)
Offline bpyeTopic starter
« on: April 05, 2016, 12:23:51 pm »
I am currently working on a project that calls for an LCD however I'm struggling to find how I can source these reliably for a project that I only intend to make 5-10 units of. I need a 2.8" LCD, and on aliexpress.com and such I have found 2.8" panels that fit within my physical constraints but ordering from such a website obviously leads to the concern that the display will disappear tomorrow. For reference something like http://www.aliexpress.com/item/2-8-inch-TFT-LCD-screen-display-ILI9341-40-pin-plug-in-type-support-8-16/32625729884.html?ws_ab_test=searchweb201556_2,searchweb201602_2_10017_10005_10006_10034_10021_507_10022_10020_10018_10019,searchweb201603_1&btsid=6055b455-c01d-412b-bcf9-4fbfb92edc5e is what I am looking for. Has anyone got any suggestions for how I can source this kind of display?
Offline nowlan
Re: Getting LCD panels in low quantity
« Reply #1 on: April 05, 2016, 12:33:52 pm »
http://www.newhavendisplay.com/ gets mentioned a bit
Offline Skimask
« Reply #2 on: April 05, 2016, 02:09:52 pm »
buydisplay.com
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline andyturk
« Reply #3 on: April 05, 2016, 03:35:44 pm »
« Reply #4 on: April 05, 2016, 03:48:51 pm »
I looked at newhaven before and unfortunately they didn't have what I wanted. buydisplay.com however looks great, they have a suitable display ( http://www.buydisplay.com/default/serial-spi-2-8-tft-lcd-module-display-320x240-optional-touch-screen ) so unless anyone has a better suggestion I think I'll go with them. Now I just need to see where I can get a gasket for the display manufactured since I need to mask off part of the display between the enclosure and the panel.
Offline Skimask
« Reply #5 on: April 05, 2016, 07:12:03 pm »
I've got a few of those 2.8" that I've played around with.  Work well enough, price is right, etc.
I turned it on.
Offline Rutger
« Reply #6 on: April 07, 2016, 01:26:20 pm »
What about a Nokia 5110 LCD Display Module, it is cheap has build-in driver and might work for you.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7 on: April 07, 2016, 04:56:30 pm »
http://wayengineer.com/ ?
I also got 100 LCD's from iTeadStudio, not board mounted. So you can get your proto running on demo kits. Then buy the separate display. If you ask, they will sell, anyone mostly.
But beware, buying an type of LCD now can mean that type is obsolete next year.
Offline RogerRowland
    • Personal web site
« Reply #8 on: April 08, 2016, 06:28:56 am »
... I only intend to make 5-10 units ...
... I have found 2.8" panels that fit within my physical constraints but ordering from such a website obviously leads to the concern that the display will disappear tomorrow...
Obvious question - why not just order 10 and be done with it?
Offline JoeO
  • I admit to being deplorable
« Reply #9 on: April 08, 2016, 08:14:04 am »
Exactly.
The displays are $5 American each.  Not exactly a huge outlay.
Additionally, you can not guarantee any company will stock these?
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
