Hi guys,
Do you think that a touch sensor under a 5mm thick plate of marble would be sensitive enough to reliably work? Or is the whole idea wrong? Not position sensitive or anything - just if the button has been pressed.
If yes, could you recommend a specific device? I know Atmel, Cypress and Microchip makes them.
Thanks,
