Thanks!
Yeah I figured it was not good practice...
The problem with the AND gate is that the signals to be switched are bidirectional (I2C).
I think I will be using the following chips :
- ISO1540 I2C isolator
- and then, on the isolated side, SN74CBT3306 to switch the signal on or off
I suppose I need pull-up resistors before the isolator, between the isolator and the switch, and after the switch, otherwise, it won't work..
M.
