Hmmm. I wonder why they didn't put the gain on the package. I would think that is important. I also checked the datasheet and didn't see that number. Datasheets are complicated and I have a hard time understanding them. But since it seems that hfe is not gain, then what is hfe?
I guess I need to watch some more instructional videos on transistors.
Thanks
Hi
Transistors, regardless of what you call the gain, have a number of things going on:
1) The current through the collector changes, the "gain" is different at different current levels.
2) The voltage between collector and emitter changes, the "gain" changes as a result.
3) The temperature of the device changes, the "gain" changes as a result
4) You buy 100 parts and look at them, some have more "gain" some have less
5) You buy the same part number from different vendors, again there is a difference in "gain".
6) You decide you want < 0.7V between collector and emitter, "gain" is different in this region.
7) You vary the frequency, the apparent "gain" gets lower as frequency goes up.
That's the "easy stuff" before you get into the weird part of things.
It is rare to find a transistor data sheet that characterizes the part under every possible condition. If you find a data sheet like that, it probably is on a part you can't afford. All of the common parts are fairly loosely spec'd. That makes them easy to produce. Easy = low cost. Low cost = we like to use them.
Bob
