Author Topic: designing a variable single output DC to DC  (Read 1566 times)
Offline BelAirTopic starter
« on: September 17, 2015, 08:25:55 am »
I am a new here. I have a few enquiries regards designing a variable single output DC to DC convereter, please:
- is there any way to generate a single output can be swing/ variable  from -5  to + 5 vdc base on the load requirements, input voltage +/-15 or +/-10 doesn't matter here as i can choose any! Also the maximum current must be 500mA.
- i have found plenty of schematics for dual outputs -/+ve but doesn't come as a single output.
- I have also used dual  inverteing and no inverting op amp and linked the output to POT to provide me a single output from -5 to +5 but with low current 10mA!!.
Your help and efforts are really appreciate.
Cheers,
BelAir
Offline nctnico
Re: designing a variable single output DC to DC
« Reply #1 on: September 17, 2015, 09:42:04 am »
Look for a class-D amplifier. You'll need some filtering at the output though.
« Reply #2 on: September 17, 2015, 12:51:21 pm »
Thanks indeed  nctnico ..
Offline matseng
    • My Github
« Reply #3 on: September 17, 2015, 02:32:41 pm »
Have you seen the OPA541 and its siblings?
The OPA541 is a power operational amplifier capable of operation from power supplies up to ±40V and delivering continuous output currents up to 5A. Internal current limit circuitry can be user-programmed with a single external resistor, protecting the amplifier and load from fault conditions.
That might be an easy solution for your requirements. The 541 is a little bit too beefy for you but there are lower powered versions of it.
