I don't know about recycling centers, but I know they're
available from many charity shops for a low price.
Places like Goodwill do sell these, but the prices can vary. Sometimes it's
easier and better to get a 'lot' (search term) of power adapters on eBay. I.e. you would search '5V ac adapter lot'. You can get exactly
what amperage you want, and get multiple of them. Though Goodwill is worth looking to see what they have if you happen to be there.
I'm not sure what is meant by 'recycling centers', but the electronics recyclers in my area are a much better deal, though you have to
be on good terms with each respective recycler. I've seen recyclers that have a pallet sized cardboard box full of ac adapters, one for
routers, one for laptops, etc... If they are nice, they will let you dig through the box and take what you want for pennies. I used to
do this for routers and ac adapters. But Gl.inet and now Openwrt One has made that obsolete for routers (it's still worth doing for
network switches). It's fascinating what you can find at recyclers. They often have electronic test equipment (I bought my TDS 2000
series tek scope from one of them). Or proto boards from local design companies, surplus wire, etc... When I say you can get things for
pennies, this usually means you give them about $100 for other things (laptops or monitors) and then they let you browse and take
whatever power adapters you want as a bonus. If you go there just to pilfer their ac adapters and network switches, they may get
annoyed. You will need some disposable income. You can also give them equipment of course.
Here's what I have learned about collecting power adapters. 1) You will want to get 5.5 and 2.1mm barrel plugs. This is the standard.
From here you can purchase the adapter sets from china that will get you universal access to devices. (See photo attached.) 2) I stock
5V, 12V and 24V, but you might also want to stock 9V. This covers most devices (and the 24V is optional.). 3) If you purchase them from
eBay, you will want to make sure the barrel plug cable is not a coax. Because if you have to solder a new barrel plug on the coax it
will be more trouble than its worth. Cables that are coax are usually a single cable, where as the divided two wire cables will have,
two wires visible. You can open up and resolder the coax ones if you had to, but again, it's too much of a hassle. Start on the right
footing, and everything afterwards will be easier. 4) I have plenty of switchers, but the older transformer ones are worth collecting as
well. These are a bit more rare, but certainly more future proof. 5) Use calipers to verify the 5.5 and 2.1mm plugs, as you will be
surprised, some of them are very close but not quite 5.5 and 2.1 (and I'm not referring to the 2.5mm ones). That's most of it, I
probably forgot one or two other things worth knowing.
12V adapters are by far the standard. Usually 12V 1A.
Could you series connect to make higher voltages?
I have done this for a led light, connecting two 12V in series to get 24V, but it's such a mess of cables and the two
enclosures that it isn't worth the trouble.
You only need so many 5W adapters.
This is also true, and you have to decide how many of these you need. You don't need an endless supply. I keep a small 1 gallon bucket filled with
each voltage and label the voltage on each bucket. That is enough. I try to stock higher amperages (2 or 3A) since the 1A are more
common but can limit applications.
There is some fun to be had with these adapters. I've wanted for a while to get a programmable DC Load and try stress testing some of
these. As mentioned, you can also put them in an oven to accelerate the aging. Or as mentioned you can adjust the voltages. You can
reverse engineer them (they are simple enough). They are common, so it's a rabbit hole that is accessible.
