Author Topic: SIM7600 HAT (WaveShare), 4G Modem  (Read 857 times)
Offline babak7293Topic starter
« on: September 21, 2023, 10:03:30 am »
I am trying to achieve the sleep mode where current consumption will only be few miliamps but it would still be able to receive text messages.
I am using the TX,RX and the DTR pin to put it in sleep mode and wake it up.
According to docs, I send AT+CSCLK=1, and also pull up DTR, the NET LED goes off so i believe is in sleep mode. However the current is about 25 mA still. It should be few mA.
Has anyone managed to put SIM7600 HAT into sleep mode? is a hardware change required (de-soldering something)
Offline Emo
Re: SIM7600 HAT (WaveShare), 4G Modem
« Reply #1 on: September 21, 2023, 11:27:50 am »
Hi Babak7293,
Sitcom does have a manual listed on its site specific for this situation; SIM7X00 Series_Sleep Mode_ Application Note
You might have it already, otherwise you could request a copy
Eric
Offline Kalvin
  • Embedded SW/HW.
« Reply #2 on: September 21, 2023, 11:51:46 am »
Are you using GPS? Have you also disabled GPS while in sleep state?
« Reply #3 on: September 22, 2023, 09:00:18 am »
thanks, I have turned off the GPS using AT+CGPS=0. I have already looked at that sleep application document, but still not able to get the current consumption down to few mA.
Offline Kalvin
  • Embedded SW/HW.
« Reply #4 on: September 22, 2023, 11:25:34 am »
It looks like there have been similar issues with Lilygo's module. Lilygo's module is not identical to your module, but quite similar.
"Power consumption of SIM7600 in sleep mode #13"
https://github.com/Xinyuan-LilyGO/T-SIM7600X/issues/13
Please read the whole thread carefully before taking actions, though.
Hope that helps.
