The working pressure range for the valve is 0.02-0.8Mpa.
0.02MPa is 3PSI.
Have you got it hard plumbed to your tap or are you just like squirting water into it.
It needs a minimum of 3PSI into the inlet before it will operate.
Scheme water tap pressure should do it.
For your tank to open it it may struggle. A 2m tall tank will have a maximum pressure of just under 3PSI so it probably wont open the valve when full and definitely wont open it when the tank level has dropped.
