@RT
No worries. I did the same thing in these very forums. One of our Spanish readers pointed out my error.
@prenato
So, both 100nanos, then? Any info on the meter (and transformer part#)?
While I'm here, how 'bout some other things?
--> The values for the 555, according to the online 555 calculator, gives us about a 145KHz output. Looking at my National (TI) datasheet, page 8, figure 6, "Free Running Frequency", the standard (analog) version of the 555 shouldn't be running over 100KHz. The CMOS (TLC or 7555) version can easily do 145KHz, so if you're having problems with this circuit, increase the value of the 470pF to about 680pF. This should give you 100KHz.
--> I think it may be prudent to those following this thread/project for us to "bullseye" that transformer. Just quantifying it as a 2:1 will have folks hooking up some 120V-60V power transformer and not getting anywhere. I don't have, nor can I seem to scrounge, any of the type I'm guessing to use, but I'd like some input from those who have this working:
- Needs to operate at ~100KHz.
- Only needs to run at ~10V or so.
- Doesn't need huge isolation value (50V is plenty).
- Small ferrite core style is preferred.
With that in mind, a couple of candidates popped up in my searches:
Murata 78604/3C RF/Pulse mode transformer.
Coilcraft WB1015-PCL Wideband RF transformer (the -SML is surface mount).
The Coilcraft site allows for free sample requests, but my browser/settings wouldn't allow me to fill out the form. Maybe some adventurous forum member could do so, try it out, and report back as to how well they work? Note that the Coilcraft is only a 1.5:1 ratio, so you'd have to adjust the output resistor on the 555 accordingly (maybe 220/270R?).
nop
