I agree with ve7xen, {73's neighbor, BTW}
If one is using a true PoE switch (PSE), it interrogates the device (PD) and looks for a valid signature (resistance/capacitance within a time frame), if it's out of spec., the switch should ignore/not supply power.
There are lousy switches that supply power- no matter what, ..and there are certifiably correct PoE switches.
Tested racks of PoE switches in the past, some are perfect..and some manufacturers have absolutely no clue..
If you want PoE regardless of any standards..then just use an injector (cheap on eBay or DX)
