Author Topic: YAMAHA YST-SW80 Home Sub Woofer Do I keep blowing it through ignorance?  (Read 979 times)
Offline modz786Topic starter
  • Country: gr
Hi Guys and Gals )))
this sub has two choices of inputs, RCA or direct Amp input with speaker out terminals.
Im wondering does it have a max amp input rating that it can handle because I cant find anywhere what the Max input watts from an Amp should be ?
The output transistors keep blowing :-BROKE
Im a newbie in the forum so can i publish a link to the schematic service manual here?
Cheers!
Offline NiHaoMike
    • Facebook Page
Re: YAMAHA YST-SW80 Home Sub Woofer Do I keep blowing it through ignorance?
« Reply #1 on: November 27, 2019, 01:51:29 pm »
Just replace the whole amplifier board with a fairly cheap class D module?
  • Country: gr
« Reply #2 on: November 27, 2019, 04:12:03 pm »
Class D, its a last consideration if fault not cured.
The volume is reduced as it still works but doesn't sound nice.
When the replacement pair of Transistors arrive I will scope the board this time
