Author Topic: Yet another Audiophile Question.  (Read 1559 times)
Offline DW1961
« on: August 04, 2020, 09:30:13 pm »
From our previous threads, it seems that driving a speaker wit less power than it is rated, much less, does not damage it if distortion is kept low enough., You just don't get any sound, eventually.
(Def: All power is continuous.)
I asked Klipsch what would happen to the R-51M speaker rated at 85/340 if I used an amp at no more than half volume and THD of 1% or less with an amp rated at 22 watts continuous per channel. This is what I got:
"Thank you for contacting Klipsch Product and Technical Support. Supplying the speaker with too little power, even if you mainly use them for low level listening, can cause internal strain and damage to the speaker's components. At a minimum, you should supply this speaker with 60 watts of power at 8 Ohms. Getting as close to the power handling will ensure quality audio reproduction and longevity of the speaker's components."
I asked them  to explain how giving the speakers 6 watts  from a 20 watt amp  (30% rated power) is different from 6 watts coming from a 60 watt amp, where both amps are putting out less than 1% THD. I don't know if that is a relevant question, but from our discussions, it seems so.
Offline tooki
Re: Yet another Audiophile Question.
« Reply #1 on: August 04, 2020, 09:49:12 pm »
I’ve never, ever heard of it being problematic to use an amp capable of less power than the speakers, and it happens all the time.
If I had to guess from their customer-service-rep-attempting-to-pass-on-some-technical-thing-they-didn’t-understand-themselves reply, the only possible concern would be if an overstrained amp starts severely clipping or something. That would add a DC component that is indeed bad for the speaker. But it’d sound awful at that point.
But with your stated constraint of “1% THD”, this variable is already accounted for.
P.S. These aren’t “audiophile” questions. Audio ≠ audiophile. “Audiophile” is a highly loaded term with lots of connotations that I don’t think you intend to insinuate.
The following users thanked this post: DW1961
Online Gyro
« Reply #2 on: August 04, 2020, 09:53:53 pm »
You seem to be starting a lot of threads on the same subject.  :-\
The reason for what they're saying is that they are trying to stop your low powered amplifier from clipping and stuffing lots of energy into their tweeter. How do you know that your 22W amplifier is only outputting 5W? Music is very dynamic with low average level and high peaks. Your low powered amplifier (at some notional 5W) is far more likely to clip (and fry the tweeters with excessive HF energy) than the equivalent 60W+ one.
It has long been known that you are more likely to kill the tweeters on speakers by using under-powered amplifiers than high powered amplifiers, used with caution of course.
Chris
"Victor Meldrew, the Crimson Avenger!"
The following users thanked this post: tooki, DW1961
Offline TimFox
« Reply #3 on: August 04, 2020, 10:47:42 pm »
Here is a classic discussion of required amplifier power, from the vacuum-tube era.
https://worldradiohistory.com/Archive-All-Audio/Stereophile/60s/Stereophile-1962-09-10.pdf
Technology and fashions change--sometimes it is hard to tell the difference.
Note that Paul Klipsch, who developed high efficiency speakers and founded the company, passed away in 2002, so he bears no responsibility for that reply.
Offline DW1961
« Reply #4 on: August 05, 2020, 12:45:27 am »
From now on it will be "Audio" question :)
Offline DW1961
« Reply #5 on: August 05, 2020, 12:52:48 am »
The subjects are specifically different, unless I've forgotten one I had started specifically. This one is more like "What damages  a speaker more, too much or not enough power?" Since I started researching this argument again, I've been reading the opposite--that most damage to speakers comes from too much power.
I don't know how much power it is putting out, but I do know the voltage knob is never over 30% off bottom, and the volume level continuous to psycho-acoustically increase until it is at its stopping point.  So, I'm assuming it is somewhere between 0 and 50%.
3116D2 Class D amplifier chip:
[attachimg=1]
« Last Edit: August 05, 2020, 01:48:18 am by DW1961 »
Offline helius
« Reply #6 on: August 05, 2020, 02:43:54 am »
The volume knob is an attenuator that reduces the input signal, it has very little to do with the amplifier power. By that I mean, it would be rare for an integrated receiver (preamp + amplifier) unit to be able to turn the volume to max without clipping. They are typically designed so that the maximum tolerable level is less than that. Why? Because not all input signals have equal levels. Some radio stations are quieter (despite AGC) and some turntables, cassettes, etc have higher outputs compared to others. If the quietest input device can be amplified to the maximum design output level, then the loudest input device must already reach that level with the volume knob only partway.
Offline mc172
« Reply #7 on: August 05, 2020, 03:03:28 am »
The way I interpret what they're saying isn't anything to do with amplifier A having a higher output power capability than amplifier B, or whatever.
Here's what they said:
Quote from: Klipsch
Therefore, the power delivered to the speaker should never drop below, or exceed 60 Watts.
The audio going into your amplifier should be as heavily clipped as possible in order to reduce the dynamic range to almost zero.
You also need to remove and bypass the volume control on your amplifier with fixed resistors (or put a screw in the volume knob, and another two in the face plate to trap it in position) to ensure that you can't accidentally adjust it to be more or less than 60 W.
Or perhaps you're supposed to deliver 60 Watts worth of DC, all of the time?
Offline ejeffrey
« Reply #8 on: August 05, 2020, 03:50:20 am »
Yes, the thinking is that if you have a 20 watt amplifier driving a 60 watt speaker system and you think it is too quiet you will turn up the volume.  But if the amplifier is clipping it won't actually get any louder so you keep turning it up and the clipping will dump a ton of power into the tweeters.  This could break them.  According to this theory, if you instead have a >= 60 watt amplifier operating at 20 watts and you turn it up one of two things will happen.  Either the system will get louder and you will be satisfied and stop turning the volume up, or you will turn it up so much the woofer starts distorting which will tell you to stop before clipping kills the tweeters.
I'm not sure how realistic it is but that is the idea.  The idea that low level listening with a low powered amplifier is going to do any damage is just plain wrong.
Offline DW1961
« Reply #9 on: August 05, 2020, 04:18:30 am »
Quote from: Klipsch
Except that it's rated at 85 watts continuous and 340 peak.
Offline DW1961
« Reply #10 on: August 05, 2020, 05:01:05 am »
From what I have read on other sites and here, you're explanation is exactly correct. If you don't turn up the volume enough to clip, then you're fine. Unless Klipsch has some sort of magic smoke inside their speakers, that rep's response must be totally full of shit. Volts are volts and distortion clipping is what it is.
What I can say is that I cannot turn these Klipsch speakers up past about 50%control knob on my Texas Instruments 3116D Class D amp because the volume in a 16 x 20 foot room is uncomfortable at about 90dBs @ 10'.  From the specs, it will put out 22 watts at 19 V at 1% THD.
[attachimg=2]
[attachimg=1]
« Last Edit: August 05, 2020, 05:02:36 am by DW1961 »
Offline jh15
« Reply #11 on: August 05, 2020, 05:49:58 am »
Back in the 70's hifi days 40 watt amps were good at blowing tweeters. Klipsch is saying a low powered amp could blow theirs while clipping. Likely they put a ballpark figure to not blast/play loud them with less than a 60w amp.
And worded not well with some tech support offshore rep.
tek 575 curve tracer top shape, 535 top shape, 465. 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P single board computer, many c-64 from my club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15 receivers, Heathkit et 3400a trainer and interface,
Offline tooki
« Reply #12 on: August 05, 2020, 09:11:19 am »
[attachimg=2]
[attachimg=1]
For sure. Those are great chips. I’m working on a project right now using the successor model, the TPA3126. It’s a drop in replacement with much lower power consumption at idle, even at high voltages.
Offline mc172
« Reply #13 on: August 05, 2020, 01:14:58 pm »
My comment was heavily sarcastic.
Offline TimFox
« Reply #14 on: August 05, 2020, 03:38:14 pm »
Measuring the actual power level from your amplifier playing music is complicated, since the waveform is far from sinusoidal and real music (not test tones) varies dramatically in level due to rhythm, etc., while you are trying to measure it.  The volume control on your amplifier is not a useful guide, and the "audio taper" may not be accurate.
Here is a suggestion if you want to get quantitative:
A normal CD player has a well-defined maximum output voltage, due to the discrete levels in the DAC.  I've found that manufacturers sometimes make it difficult to find this value.  If you need to measure it, the NAB has a test CD available with specified levels on different tracks:
https://www.nabstore.com/NAB_Broadcast_Audio_Test_CD_Vol_1_p/cp400.htm  (price $20, but currently out of stock).  My CD player has a full output level of 2 V rms on the normal analog outputs, which is typical.
Now, you need to calibrate your volume control.  If you have a stepped-attenuator (or a detented potentiometer), you only need to count clicks, otherwise you need to improvise a dial.  Do these tests at a low output level, well below the amplifier maximum, to avoid damage.  You need to connect an audio generator (set to a convenient frequency such as 1000 Hz) to the input and a load resistor (4 or 8 ohms, according to taste) to the output and measure the input and output voltages as a function of volume-control setting with a good AC voltmeter (true-rms is nice, but not required, since we are dealing with low-distortion sine waves).  As you decrease the volume control (increased attenuation), you will need to increase the generator voltage to keep the output voltage at an easily-measurable level.  The mean (not RMS) output power in this steady-state measurement is the V2/R, where V is the RMS voltage across the resistor R
Now, when you listen to a favorite CD, you have a method to judge the amplifier power that gives you the sound level you want for your music.
Online Bassman59
  • Yes, I do this for a living
« Reply #15 on: August 05, 2020, 09:42:05 pm »
Think about what causes driver destruction.
First, there's the obvious -- over-excursion. A too-loud impulsive sound like snare drum or the cannon shot from the "1812 Overture" that's well above the average level of the music launches the driver out -- and never to return in. Ooops.
But the most common mechanism for driver failure is thermal overload. Too much power. Area under the curve.
It's common to think about audio power amplifiers as being "power" devices, because their outputs are given in watts and all of it. But they are really voltage amplifiers that can source or sink a lot of current.
This means that there's an upper limit to an amplifier's output, which is the supply rail. Hit the rail and you clip, we all know that, right?
What happens when you clip a signal? The simple answer is that the output stays at the rail for the duration of the time that the input voltage times the gain wants to exceed the rail (plus, perhaps, an overload recovery time).
And all of the time sitting at the rail means you're just dumping current, in a DC sense, into the voice coil and you're baking it.
The amplifier with the higher voltage rails ("more power") would allow a higher-level output to go through unclipped, and because real music waveforms don't sit at a peak for very long, a peak doesn't damage the driver because it's not generating enough heat to do so. The amplifier with the lower voltage rails ("less power") clips and stays at the rail and thus a constant voltage level, generating more heat in the voice coil and eventually the driver dies.
As for the Klipsch minimum-power recommendation, it's silly. As long as the amplifier output is clean, not clipped, a 5 W amplifier won't damage the speakers.
Offline TimFox
« Reply #16 on: August 06, 2020, 01:21:15 am »
Going back to my serious suggestion on how to determine quantitatively the amplifier power you need.
This can be simplified:  start by playing your typical CDs and note the highest volume control setting you used to get the desired sound level for your personal taste.
Then do my suggested measurement of amplifier output vs. input voltage at that setting, assume the peak level input is the CD player rated output, and that will give you (by careful algebra) how much peak power you were using.  That would represent a minimum power that you actually need.
The basis of this method is the well-defined peak output of the CD player.
Offline bson
« Reply #17 on: August 06, 2020, 03:06:13 am »
There are few absolutes though.  Most commercial amplifiers sold have soft-clipping circuitry, exactly to protect speakers (and prevent sonic artifacts).
Class D amplifiers can boost their output above their supply voltage - part of why they're so great on battery power.
Offline tooki
« Reply #18 on: August 06, 2020, 11:02:29 am »
Well, a few can, especially newer ones with purely digital inputs. But when researching this topic earlier this year, I was surprised to learn that the vast majority of class D amps require high voltages for high outputs. I looked at the designs of a few Bluetooth speakers and found they used boost converters to create the supply voltages for the amps. I couldn’t find any analog-input class D amps with more than a couple of watts output power that could do so on low voltages.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #19 on: August 06, 2020, 12:18:37 pm »
IMO, their response was just plain wrong. @Bassman59 gets right to the heart of the matter- it's area under the curve. Though not widely understood/accepted, the whole "clipping causes high frequencies that blow tweeters" myth is just that. The idea that clipping creates high frequency signals sufficient to blow tweeters doesn't work out when you do the math. What happens is if you're running at a high enough level to clip badly, you're running too loud and the tweeter is overloaded regardless. A high power amp at the same level, sans clipping, would blow the tweeter as well. Area under the curve. Audio is so full of misinformation you really need to study basic electronics, not "audio electronics."
The following users thanked this post: retrolefty, tooki, eplpwr, DW1961
Offline tooki
« Reply #20 on: August 06, 2020, 04:27:43 pm »
So true. Very well said.
Offline TimFox
« Reply #21 on: August 06, 2020, 05:41:06 pm »
Also, one should try to answer questions quantitatively based on measurements.  A real A/B blind test is nice in theory, but most reports seem to be along the lines of "I changed this part/tube/speaker and the sound/staging/etc. improved/degraded", although the changeover was far from instantaneous or blind.
Offline robca
« Reply #22 on: August 06, 2020, 09:21:02 pm »
I'm confused, sorry. I do understand that a long duration DC signal will fry a tweeter. I'm just confused on why the exact same amplifier with, say, a +-12V rail can damage a tweeter more than the twin with a +-24V rail, assuming the output signals are identical amplitude (hence the 12V one is clipped)
I created two horrible Paint JPGs, showing what I mean. Same signal overall amplitude, in one case clipped at an arbitrary height we can call 12V, another full swing. In both cases, the area under the curve is in red. And in the clipped version, the area under the curve is smaller. More complex waveforms will look similar, unless the recovery time from clipping exceeds the highest audio frequency. But even at 44KHz, that would mean a recovery slower than 22 micro seconds
Is recovery from clipping that slow? Or am I missing something else?
« Reply #23 on: August 06, 2020, 11:24:19 pm »
As usual, Rod Elliott explains things better than I ever could- https://sound-au.com/tweeters.htm
Offline robca
« Reply #24 on: August 07, 2020, 12:19:54 am »
Relevant part here:
A persistent myth in the audio industry is that clipping damages tweeters, so you should use a bigger amp to ensure more headroom so the amp won't clip.  This claim is simply bollocks!  Take the 100W amp described above, and replace with an amp big enough to prevent clipping ... even with the additional 12dB input signal as shown in Figure 7.  Since a 100W amp was just below clipping with an average output of 16W, if we add 12dB that takes the peak amp power to 1.6kW (near enough) and the average power will be 254W.
Do you imagine for an instant that this amp won't blow the tweeters (and everything else) if the input level is increased by 12dB (until it's just below clipping)?  Everything will fail, and usually fairly quickly if the speaker was designed for a 'nominal' 100W input.  It is simply nonsense to imagine that the loudspeaker drivers in a 100W speaker can survive an average power of over 250W and peak power of up to 1.6kW.
Which is exactly why I was confused by the statement that a higher voltage rail will not cause problems. The contrary is true: assuming two identical ideal amplifiers with the same input and amplification factor, one with 12V rail one with 24V rail, the one with 24V rail will blow the tweeter faster
And what the Klipsch rep said is wrong.
