Thanks for your answers, I connected a 15V 3A power supply, I made a small circuit with two transistors and two LEDs, one red that indicates heating and one green that indicates the RB is in Lock, I used Pin 3 Bit Lock, I put it in ON, the red LED immediately turned on, after about 5 minutes the green LED turned on, I connected an oscilloscope and I got 10Mhz and 2.5V peak to peak.
I tried to connect it to the GPSDO Project, connected in this way 10Mhz output to the 100 ohm resistor and Pin 8 (Freq. Adj) to the pwm dac unfortunately it does not work it always remains in Calibration, I was curious to see the Rubidium controlled by the GPSDO, if I connect the ocxo it works as you saw in the previous photo, then I tried to connect it to BG7TBL it works very well in 35/50 minutes it went into Lock, I do not understand in the AndrewBCN project it does not work.
