Author Topic: Yet another resistance decade box  (Read 112412 times)
Offline johnmx
  • Country: pt
Re: Yet another resistance decade box
« Reply #275 on: July 29, 2016, 09:40:00 pm »
Fortran, in order to prevent shorts during soldering I recommend you to make tented vias next time (no solder mask opening).
ez24, if you have a short circuit you can desolder the resistor (keep heating both sides 1s at a time until the resistor gets loose), remove the excessive solder on the board with solder wick and solder the resistor again.
Best regards,
johnmx
Offline ez24
  • L.D.A.
« Reply #276 on: July 30, 2016, 01:28:52 am »
I will try this if I run out of boards.
Did another one today successfully but ugly. The problem I have is leaving "whiskers" when I lift the iron.  I always have to go back and try and level them.  Sometimes I can and sometimes I cannot.
I have a question: what do people do with the standoffs?  When I started, I trimmed off all three, then I tried just the center, then I tried not to trim any.  Without trimming any I got the board out ok but I could not get the new one in.  In fact I destroyed the switch trying to get it in.  So I went back to just trimming the middle one BUT it seems the middle one is the most important to keep the switch wipers touching the board.  Just curious on what others are doing.
When I am done and before I assemble them, I think I will take a hot needle and press down in the center of the ones that I cut to make them spread out a little.
Vias
It seems to me, with a 10x glass, that the vias at 2,7, and 9 are actually touching the pads, whereas in the picture they do not.  I am afraid to test with a meter because if they are not touching, the probe would probably make it contact (it is that close). I try very hard to keep solder away from the via and it seems to work.  Comments ?
Offline Fortran
« Reply #277 on: July 30, 2016, 05:37:45 am »
Whiskers can have a few reasons.
Heating too long burns away the "wetness" and solder clings instead of flows.
Is your tip clean?  It should be silvery and shiny.
If it is..  have you tried adding flux?
If it still won't cooperate.. try a different/better solder. The cheap stuff is usually a nightmare to work with.
What's the dia on your solder? It might be too thick and that's no good either.
Standoffs:
You only need to cut the two. Use a scalpel or box-cutter to cut them flush to the board.
The vias on 2, 7 and 9 are connected to those pads, so a short there does nothing :)
It's only the one under 3 that's a potential risk of shorting.
Offline ez24
  • L.D.A.
« Reply #278 on: July 30, 2016, 06:34:18 am »
--> I do not think this is the problem, I do not spend much time on the pad
-->  Yes I clean it each time I use it
--> I will order a flux pen, I do not have any
--> I use Dutch Boy, I think it is good  (but very old maybe 50yo)   I will order some new solder - Kester
https://www.amazon.com/KESTER-SOLDER-24-6040-0027-Stand-Diameter/dp/B00068IJPO/ref=sr_1_7?s=hi&ie=UTF8&qid=1469859605&sr=1-7&keywords=rosin+core+solder
--> Very small, my guess .5 mm  The Kester is .031", which sounds very small to me
Standoffs:
--> now that I think of it, it is probably better to cut the pair and leave the center.  I will try that on the next one
--->  :phew:  this will help a lot. I was trying very hard not to get solder near the edge of the pad
So far I have done 3 good ones and 1 bad one  :-+   Not bad for an old fart.
thanks a lot - this will help
Offline Fortran
« Reply #279 on: July 30, 2016, 07:08:45 am »
Yeah that might be it.
Solder usually have an expiration date. It's probably fine a decade or so after that, but still. If it's 50 years old it wouldn't harm to try a fresh one.
I've never used Kester, but from what I've heard it's good stuff.
0.031" is about 0.78mm.  That's quite thick for SMD.
I'd go for 0.5mm or smaller just to have better control over the amount of solder you're putting on.
If you want to I can send you some 0.3mm, 0.5mm and 0.7mm to compare.
Offline sq9nje
« Reply #280 on: August 01, 2016, 10:08:56 am »
Hey Guys,
I just ordered 3 sets of boards with 1% resistors. The switches will probably take ages to arrive though...
Przemek
Offline Fortran
« Reply #281 on: August 01, 2016, 02:10:01 pm »
Thanks Przemek.  It's been shipped.
Update:
The new resistors have arrived!
But the pre-orders grew during shipping so I'm already out of 0.1% kits.
So, ONLY 1% kits are available at this time, but I have plenty of them.
Offline johnmx
  • Country: pt
« Reply #282 on: August 01, 2016, 02:28:55 pm »
Here is the finished decade box.
I used an old lithium battery box.
The overall size is rather small: 114 x 52 x 20 mm.
The banana connectors keep the box closed without using any screws.
The parasitic resistance is around 0.5 Ohm.
Best regards,
johnmx
Offline Fortran
« Reply #283 on: August 01, 2016, 02:50:31 pm »
Nice and compact  :-+
Offline sq9nje
« Reply #284 on: August 01, 2016, 04:28:23 pm »
Man, you're fast! Thanks Fortran! Will report back when I receive them.
Offline bitseeker
« Reply #285 on: August 01, 2016, 06:13:34 pm »
That is excellent, johnmx! Looks good and is very compact.
Offline Blastcap
« Reply #286 on: August 02, 2016, 01:20:38 pm »
Doing some last minute shopping, could anyone confirm that these will fit?
http://www.mouser.de/ProductDetail/CHERRY/PBC1-E015/
Its a 10 pack from "Cherry", they can't be too bad.
EDIT:
Don't buy these... they won't work!
« Last Edit: August 09, 2016, 08:37:45 am by Blastcap »
Offline BFX
  • Country: sk
« Reply #287 on: August 03, 2016, 04:46:39 pm »
Just got mine two sets   8)
Waiting for switches.
Thank you  :-+
Offline Janne
    • Projects
« Reply #288 on: August 03, 2016, 07:27:30 pm »
2 sets received today, very neatly packaged!! thanks  :-+
Nothing's as easy as drilling a hole in the wrong place
Offline Fortran
« Reply #289 on: August 03, 2016, 07:45:30 pm »
Great  :-+
Happy to see that everyone seems pleased  :)
Offline ez24
  • L.D.A.
« Reply #290 on: August 03, 2016, 10:58:56 pm »
I got better at soldering, the main improvement was to hold the iron on the pad for about 2 seconds before adding solder (to prevent whiskers)   Now I have gone from 10% success to 90% i :-+
I got a sample of the "big" switch and I like it.  It is easier for me to use.  I thought maybe I could wire up external caps and make a cap decade box BUT it is a BCD switch.  I never saw one of these.  I assume you need TTL logic to make it work, but I wonder if some sort of decade box could be made with it without TTL or MCU?   Maybe I should start a topic on it.  Does anyone have any ideas?  thanks
Again I want to say thanks Fortran for this project.  The professional quality was a surprise.
Offline Back2Volts
« Reply #291 on: August 04, 2016, 03:25:40 am »
...  I thought maybe I could wire up external caps and make a cap decade box BUT it is a BCD switch. ...
There are at least two variants of the switches I know of,   BCD and (straight) decimal.   Just because I was looking for different colors ones I ended up ordering some decimal and some BCD.
Offline ez24
  • L.D.A.
« Reply #292 on: August 04, 2016, 03:46:41 am »
Thanks I will look for a large decimal switch.
Offline Narmaraktuk
« Reply #293 on: August 04, 2016, 06:51:09 am »
Just received a well-packaged set from Fortran. Many thanks!
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #294 on: August 04, 2016, 09:20:26 am »
I've received the second packet as well - thank you!
Cheers
Alex
Offline gblades
« Reply #295 on: August 04, 2016, 01:25:37 pm »
I would have thought BCD might actually be better for a capacitor box due to the way you stack capacitors in parallel to combine the capacitance.
With a digital output you would need 1 of 1nf all the way through to 9nf. With a BCD output though you only need a 8nf, 4nf, 2nf and 1nf. The 1,2 and 4nf you can make up by stacking capacitors side by side or on top of each other of there is enough room. The 8nf then is a bit more awkward as 8 caps are a bit too many to stack but even so it does make it simpler and reduces the number of different value capacitors you need to purchase.
Offline Fortran
« Reply #296 on: August 04, 2016, 02:21:13 pm »
Here's my box :)
They're both supposed to be short, but I broke my last M2 tap on the first hole  :palm:
Can't screw it together until I get a new one so I'm using an uncut box until then.
Offline Back2Volts
« Reply #297 on: August 04, 2016, 04:45:52 pm »
Fortran, nice!     What are the dimensions of the box, 60x55x25 ?    Is the body just one tube piece?   How do you cut it?    I was thinking about running an aluminum box through my 10" table saw, but it kind of scares me :-//
Offline Iwanushka
  • Country: lt
« Reply #298 on: August 04, 2016, 05:49:32 pm »
Here's my box :)
Nice boxes, do you mind sharing a link to them?
When all you've got is a hammer, everything starts looking like a nail.- Attrition.
Offline Fortran
« Reply #299 on: August 04, 2016, 06:28:32 pm »
It's 80x50x20
http://www.ebay.com/itm/172255252886
But I cut it down to 60x50x20 with a metal band saw.
Mine looks like this:
But a regular vertical one would work too. Just screw it together first so the pieces are aligned, and cut slow and carefully.
The endplates where cut with my CNC mill, because I'm too lazy to do it manually :)
