Thanks everyone for the tips and ideas! The video with the cheap radar sensors was very interesting, too bad that the reviewer couldn't figure out how they worked either
The construction of my unit is quite different though, it doesn't have the serpentine strip that all units in the video have, and has that mysterious brass bar instead.
There is nothing under the brass strip, it is just a strip, raised approximately 4 mm above the PCB. The brass is quite sturdy, it doesn't move or vibrate without applying quite a bit of force. The plastic piece at the end is a plastic screw, with a head for a flat head screwdriver at the bottom. Is it possible that they use a screw instead of a single post or standoff to be able to precisely tune the distance between the PCB and the brass?
There must be a good reason for that bar, since it is the only hand-soldered component on the PCB, and inserting the plastic screw must also take time and effort.
