Hello! Well, I have a moped with a charging system that barely gives 13V at idle rpm and goes up to 13.2V at full rpm. The consequence of this is that the battery charges very slowly and I end up being stuck with a dead battery quite often, since the discharge rate is much higher than charging rate. Instead of replacing the whole rectifier, can I use a cheap DC-DC step up converter to provide the battery with constant 13.8V-14V from a 13V-13.2V input? If it was pure DC I wouldn't ask this question, but the output signal of the rectifier is something like a chopped AC, it looks more like square wave output.
