Author Topic: Connectors for large 7 segment LED  (Read 599 times)
Offline rcbuckTopic starter
« on: April 08, 2021, 10:18:32 pm »
I bought some large 2.3 inch 7 segment displays to build a clock. The connector pins on the back of the displays are 0.020 inch square posts. Does anyone know where to find female connectors that would mate with these pins? I tried the standard 0.025 connectors but I think they are too loose to make a reliable connection. The only other option I see is to solder wires to the pins. Photo of the display back side is attached.
Online georges80
Re: Connectors for large 7 segment LED
« Reply #1 on: April 08, 2021, 10:40:53 pm »
Why not lay out a PCB, then you don't need to 'wire' anything and you can integrate all the clock stuff on there too...
cheers,
george.
Offline tooki
« Reply #2 on: April 10, 2021, 02:19:16 pm »
You don’t say specifically, but reading between the lines, you want to connect wires to these, not a board?
If so, and the pin pitch is 2.5 or 2.54mm, try either JST XH or Molex KK 254 (or any clone, thereof, like the KF2510 series on eBay/AliExpress). They both use the folded contacts that are quite tolerant of pin size.
But clearly these things are designed to go in a PCB, and that is what I’d recommend first and foremost.
Offline coromonadalix
« Reply #3 on: April 10, 2021, 02:43:08 pm »
why no design a pcb who just  fit under the display to  standard pinouts ??  bread board compatible  etc ...
