If you manage to send out your pulse you severely endanger the hearing of those wearing the receivers. The same applies to those wearing hearing aides and pace makers. Even if you send out much lower energy you are still risking this.
First few posts:
"Students with hearings-aids or pacemakers are segregated."
And, assuming you manage to create your stupid pulse, do you have the funds to compensate not only the people you hurt, but also all people for all the other damage to electronics it will do? E.g. killing people's digital watches, cell phones, labtops, iPads, their normal MP3 players, their car keys, their credit card? And is your uni willing to re-equip the lecture room every time you send out you pulse, after you killed equipment like projectors, the loudspeaker system, lights dimmer?
Electronic equipment is strictly forbidden in exam rooms, everyone knows the rules before going in, even if we had 1 million dollars or so to spare on generating an explosive EMP blast to be anywhere near powerful enough to remotely reach the level of EM required to collaterally damage any equipment unintentionally, yes, we would be technically held accounted for that.
should be covert, able to be mobile, say in a backpack with a few 9V batteries or other power source that is small enough to conceive in a bag.
Really? Why?
Apologies for the "covert" request, after having the EMP image from Ocean's Eleven in my mind, I was aiming to get the opposite of 'gigantic' and accidentally over stated the dimensions required. Looking for small and somewhat reasonable dimensions to still be classed as 'portable'.
I should also warn that a true 'far-field' high power disruptive or damage capable EMP emitter could be considered by the authorities to be a terrorist tool so it's not something to be played with.
What about lower powered disrupters covertly and strategically misplaced in rucksacks then...
GSM jammers anyone? GPS jammers? Used by car thieves to jam the satelite tracking system for stolen vehicles, yet, readily available to anyone even if not in law-enforcement.
You are better off just broadcasting something stronger in the same spectrum as their ear pieces, continuously- as John suggested. EMP is a pretty a dumb and nonsensical approach to this.
Thank you for this. Have been heavily considering this option and transmitting over 1-1.5Khz.
- Who -DOES- use loop technology legitimately? Mass transit facilities, museums, theaters, hospitals, schools, the Secret service and other law enforcement folks...
Exactly, that's very true. Cheating on exams isn't legitimate, but preventing such occurances withing the extent of the law, taking the human condition into consideration is perfectly legitimate.
- If the goal was to stop cheaters, you wouldn't build the jammer into a backpack, you'd put it in a big shiny box on the wall with a flashing red light and tell EVERYONE ABOUT it.
We have a jammer which ranges from 80Mhz to 3.2Ghz if I'm not mistaken, the configuration isn't superb but is working, power consumption is awful, it's turned on at the mains often and barely visible on the wall-mounted setup. We have a portable one also with a much reduced range but works like a charm for the desired application.
EVERYONE here has contributed greatly towards the cause, even as negative as some comments might have sounded.
Thanks all, very much appreciated.
