Poor man's frequency response analyzer(Gain and Phase measurement of a flyback supply)
This video is a follow up to a previous video where I used a Venable Frequency Response Analyzer (FRA). Most FRA are out of the budget of most small business or hobbyist. However, you can use a function generator, an injection transformer, and a scope to measure the stability of a power supply such as a flyback.
By injecting a signal and measuring the amplitude and the phase delay, you can measure three critical power supply specifications such as the crossover frequency, phase margin, and gain margin.
You can use any wide band transformer as long as the transformer bandwidth is 1 MHz. The only negative of using an off the self transformer is that they have high capacitance from the primary to secondary in the 1.5 nF range. However, if you can wind your own transformer and use a split bobbing, you can greatly reduce the primary to secondary capacitance. The transformer that I wound measured a total of 15 pF between the primary and secondary
Question and comments are welcomed!
