Hi PepeChip,
Kleinstein already explaned wath i would say about de Darlington repalcement.
But there could be another prpblem, and this is generation of the 2N2905 it need a resistor directly on de base of about 47 Ohm.
But also this, the 2N2905 is not good enough for 200mA, the Hfe drops quickly above 100mA.
And the dissipation is nog high enough.
Just a bad part for your application!
Than anything else, how "perfect" should this voltage reference be?
Have you thought about the wiring problems?
Can you show some pictures of your test setup?
Kind regards
Blackdog
