Hello folks,
I have a prebuilt HP PC with a proprietary (non-ATX) motherboard power connector. I want to use a GPU in it that requires more juice than the piddily 280W stock PSU can supply. While I wait on an adapter to arrive that will let me use a standard ATX PSU in it I wanted to power the GPU externally through a separate PSU.
I've successfully done this by jumping the secondary PSU's PS_ON wire to GND without much issue. However, it's annoying having to turn two power supplies on/off. There's no easy way to splice another wire to the PS_ON connection of the primary PSU, so I decided to build my own version of one of those
Add2PSU modules. From what I can tell, these modules tap SATA or Molex 5V from the primary PSU to control a relay which shorts the PS_ON of the secondary PSU to turn both supplies on/off simultaneously.
My question is - why use a relay instead of a MOSFET here? To my knowledge, ATX GND is tied to mains earth, so both supply GNDs should be the same and there's no need for isolation...is the only reason for a relay to account for improperly-grounded or multi-grounded house wiring? If I know my PSUs share the same earth, then I could just use a MOSFET, correct? I have so much electronic junk piled up in my tiny apartment that I can't find a 5V relay at the moment (plenty of 24V ones though
), but I do have some 5V FETs on my desk.
Any other gotchas I should be aware of? I'm not new to electronics but I've never worked with PCs at an electrical level so I want to be cautious :-)
Thanks in advance!
