Author Topic: new lithium ion 18650 battery build  (Read 505 times)
Online m3vuv
« on: May 08, 2021, 09:02:36 am »
I am planning on a new 18650 triangle battery build using samsung 15q 18650 cells ,its going to be a 13s 8p,i see repakir to match the cells capacity but no mention of the cells internal resistance,im testing all the cells using a litokala engineer lii-500,some of the cells read 30 milliohm ir and some 125,how should i arrange them regarding internal resistance to keep them ballanced,i have a bt smart bms but want to do the best i can to match them for ballance,cheers in advance.
Online m3vuv
Re: new lithium ion 18650 battery build
« Reply #1 on: May 10, 2021, 08:57:43 pm »
can no one shed any light on this??
Online tunk
  • Country: no
« Reply #2 on: May 10, 2021, 10:05:14 pm »
Not sure if a charger is a precision instrument, so the internal resistance
measurements may not be very accurate. Have you tried to measure it several
times for the same cell (taking it out for each time and then reinserting it)?
You may also want to check the self discharge.
Offline uer166
« Reply #3 on: May 10, 2021, 11:27:13 pm »
Only use new cells for a new pack. That is a huge range of internal resistance, new cells shouldn't have that.
Online m3vuv
« Reply #4 on: May 10, 2021, 11:33:13 pm »
is the ir very important?
