"real metrology grade"
says 1% on top
Please, can you just go away now, we are dying out of laughter. I think you have totally lost all credibility by now.
Oh come on man, what's wrong with you? Can you just stop acting so childish, trying to prove to everyone that you are absolutely right and the superiority of your design, which is objectively wrong (against industry standards)? I’m not even talking to you, but you continue to try to start a flame with arguments to the individual. Just stop it, it's not your personal blog about how cool you are in engineering.
Oh come on man, what's wrong with you? Can you just stop acting so childish, trying to prove to everyone that you are absolutely right and the superiority of your design, which is objectively wrong (against industry standards)? Its pointless talking with you. You don't listen.
The labelling on that Bourn's 4-port resistor seems to indicate its 500 micro-ohms. The OP is using 1 milli-ohm. At 1 milli-ohm a large SMD resistor with good layout can match the performance of these 4 terminal resistors down to 0.1%. At 100 micro-ohms this become hard, and a well designed 4 port resistor has big advantages. There is, obviously, a sliding scale in between. A well laid out SMD resistor works well enough, that now people like Analog Devices (and me - I came to the same conclusions as AD, doing the same research for the same reasons, but they published their app. note first) have published information on the most successful layouts for high volume manufacture, resistor makers widely endorse those ideas. There is no magic in spending extra for a 4 port resistor when a little care in design can match it with smaller cheaper parts.
Oh great, another one with a high ego and low qualifications. I hear you perfectly well, I just ignored you in order to avoid a useless argument, so as not to hurt your feelings and provoke a conflict. But it seems that you are looking for conflict as a way of self-affirmation, and perceive my kindness as weakness, as an easy target for your attacks. Therefore, I simply have no other choice but to expose you to your own mistakes in order to shame and stop you.
First of all, you both have no idea what a "real" current shunt is by industry standards. No, it's not just a low resistance resistor. Let me enlighten you: this is a very specially designed resistor specifically and exclusively for use in measurement circuits and instruments (a metrology grade "resistor" = a “real” current shunt). Its main difference is greatly increased power dissipation to keep temperature rise low and minimize the significance of TCR. You are mixing together the concepts of current limiting for overload protection, where high accuracy is not needed, and current measurement for regulation, where high accuracy is needed.
You also have no idea that TCR is a curve that is relatively straight only in a narrow range that ends much earlier than the operating temperature of your standard 2512 resistors at 1 W or more. The manufacturer doesn't even bother to give this information to you for regular resistors because they were never supposed to be used for accurate current measurement. The manufacturer is counting on you to be skilled enough in these matters to know this on your own and understand this from the list of applications.
Is your ego big enough to argue with the manufacturer?
And are you really going to pretend to be a fool who doesn’t know the definition of the word “example”? From the photo I provided, you can clearly see the markings, which you can use to find the datasheet and select exactly the resistance value you need. As for the value of resistance: in itself, it has nothing to do with the accuracy of measurements, unless you bring into the context the operating current and power dissipation, that is, the operating temperature. Moreover, a CRE2512 resistor will never match in performance to a proper current shunt like the CSS4J-4026 series. Why, you ask? See above: due to the ability to dissipate much more heat and operate at much lower temperatures, reducing the significance of TCR to a minimum. And no layout will help change this, because the hottest point is in the center of the resistor, and the thermal conductivity of its tiny leads is too low to remove heat quickly enough for any accurate measurements. It's funny that Siwastaja correctly noted earlier that for accurate measurements you need to derate the power rating (by about 10 times – note from me), but then he ignored himself and continued to argue with argumentum ad hominem.
If you don’t believe me, then teardown any large-scale device that is designed to accurately measure current, at least your multimeter, and you will see confirmation of my words right there (and you will never ever find there your CRE2512-resistor-like-design, if it’s not a Wun Hung Lo product). The OP expressed concern about the accuracy of the measurements, so it can be assumed that he needs it. Then he asked to name possible alternatives for this. So, this is exactly the alternative according to industry standards, that he needs. Why do you so mad about this? Maybe because you made the same mistake as the OP earlier in your designs, and now you don’t want to admit it even to yourself? It's none of my business and I really didn't care until you started dragging me into it.
Finally, regarding the 4 terminals. First of all, this hints to you that you have the proper current shunt for really accurate measurements. Secondly, even Siwastaja himself encountered and admitted a problem with two-terminal resistors, which he mentioned above:
Exactly, and the current distribution is hard to perfectly control even within the footprint of a single resistor, it depends how the part gets aligned during pick&place and how it moves during reflow.
And guess why? Simple: because it's the wrong design for accurate current measurements. PCB assembly machines were never intended to work with such high precision, unlike CNCs, which make proper 4-terminal current shunts that you can't screw up with a misaligned installation.
Any sufficiently advanced technology is indistinguishable from magic, especially if you don’t know, how it works.
