Or better yet, don't play around with these cells at all. You are not supposed to handle them, at all, they are for professionals who know what they are doing.
This being said, at the bare minimum, follow the procedure for overdischarged cells: charge at VERY low current, say C/100, for an hour or so; if the voltage isn't rising, and if it's not holding after such charge, the cells are leaking (self-discharging) too much to be safe. Only after you have verified such C/100 charge gets them to normal voltage range (i.e., over 3.4V), and they stay there - you can rest them for a day, for example - only then commit charge at regular rate like C/2.
