Note that after suddenly stopping a charging current (by removing the cell from a charger), initially the voltage drops a little bit, this phenomenon is called "surface charge", I don't know if it's a scientifically valid name or not, but anyway it exists.
You can see how the voltage drops considerably during the first second or two after removing from the charger, but this goes on possibly for hours. So if you want reliable self-discharge measurements, you should wait to make your "initial" measurement, I'd recommend going as far as waiting 24 hours to be sure.
Self-discharge itself is minute enough that measuring it requires long waiting times. I studied this extensively, and my waiting period was 1.5 years. It paid back, since I was actually able to properly quantify the self-discharge of fully charged cells stored at room temp. Had I tried to do it over just a few months, I would only have read some noise due to too little self-discharge. Any measurement method will have noise.
The self-discharges in my tests varied between 0% and 15% per year, depending on cell brand, storage temperature, and SoC. 2-6% per year is fairly typical range for a fully charged (4.20V) cell at room temp (23 degC). Cells at 50% SoC have almost no leakage at room temperature. In most cases, it was impossible to measure at all with 1.5 year waiting period, so most of my self-discharge data is from the 80% and 100% SoC samples.
Sony cells were the best with lowest self-discharge.
You could measure the voltage every week during a month to see if the leakage continues, or if it was just the after-charge surface charge dissipating.
If you they leak more than about 1-2% per month at room temp, fully charged, they have likely gone very bad.
