Author Topic: 9V Batteries chart and curves / Is common Alkaline battery is better choice for…  (Read 4485 times)
Offline 001Topic starter
  • Country: aq
Hi!
This is another "DDM battery tread" and I found interesting links:
On-line comparision http://lygte-info.dk/review/batteries9V/Common9Vcomparator.php
and
Idividual curves http://lygte-info.dk/review/batteries9V/Common9VIndividualTest%20UK.html
I see what at low currents (aka DMM) common Alkaline battery far better then LiIon/NiMH accumulators
Is it true? Is common Alkaline battery is better choice for 9V DMMs?
« Last Edit: November 03, 2017, 12:56:31 pm by 001 »
Online Nusa
For that you have to define "better choice".
Single-battery price?
Battery availability?
- Alkalines are pretty universal worldwide.
Operating cost over time?
Rechargability?
- Eliminates non-rechargeable types.
Operating time on one charge? (need to know the minimum operating voltage of meter to interpret curve)
- Non-rechargeable lithium will win here.
Something else?
Some combination of the above?
  • Country: aq
Thanx fo quick answer. Nusa  :-+
See my links abowe and note that alkalines operating time at low current apps is longest, quiet,  cheap (low cost per time, not energy)
LiIon good for current loads/ but 9V LiIons have built in DC/DC converter. so hum is not good for measurment tool PS
Why some peoples on this forum steel trying to replace alcalines with others types?
Offline ebclr
Your 1st priority must be leakage safety
Multimeter consumes very low battery, but if a leak happens will destroy the meter
The following users thanked this post: wnorcott
Offline edavid
This is wrong.  Only the USB rechargeable types have a DC-DC converter.  The more common Li-ion 2 cell types are perfect for DMMs.
Example: http://lygte-info.dk/review/batteries9V/Conrad%20energy%20LiIon%209V%20500mAh%20(Blue)%20UK.html
"These batteries have more than double capacity compared to NiMH 9V batteries and are close to a alkaline battery at low load and this battery will maintain high capacity and voltage at high load."
  • Country: aq
What we have with LiOns?
 :-+  Big currents and fast charge
 :-- 8.5v 7.4v only, price about 10 common alkalines, no frose
Is it ok for DMM?
But ebay prices tease me with soshine https://www.ebay.com/itm/Soshine-9V-6F22-650mAh-batterie-rechargeable-Li-ion/253208146299?hash=item3af461b17b:g:tRsAAOSwrwxZ4h6X  :-DD
But… For my three DMMs i use three $1 alkaline batteries per year i.e. $3 per year
UPDATED: I`m so stupid. GP  at my local store about $0.3 only https://www.auchan.ru/pokupki/jel-pit-gp-1sht1604-6f22-krona.html :palm:
What advantage I miss?
« Last Edit: November 03, 2017, 04:47:28 pm by 001 »
Offline edavid
Is it ok for DMM?
It starts at 8.4V.  It is certainly "OK for DMM".
On US eBay we can get EBL brand 600mAh Li-ion for about $3 each.
If you only change the battery once a year, you probably don't need them.  I usually have to change them more often.
That is carbon-zinc, not alkaline.
Less chance of leakage.
« Last Edit: November 03, 2017, 04:59:24 pm by edavid »
The following users thanked this post: 001
  • Country: aq
Is it problem since 9v batteries are hermeticaly sealed?
(All mess inside)
Offline edavid
(All mess inside)
They are not sealed.  The extra layer of packaging helps, but alkaline 9V batteries still leak sometimes.
« Last Edit: November 03, 2017, 06:03:35 pm by edavid »
Online Kleinstein
Even brand name 9 V alkalines sometimes leak, but not often and usually only when left in the instrument even when dead for a long time. However the amount of fluid is often small, so the damage can be limited. I have not seen NiMH Cell leak, but similar made NiCd sometimes do.
Whether rechargeable is worth it, depends on the usage. Standard NiMH tend to have too much leakage to be useful in a low current application. If you need to replace the batteries often (e.g. more than every 3 months) it might be worth the rechargeable.
It depends on the meter, how well the operate with a lower voltage when the battery is near empty. Some are more picky than others. I know of some calculators the could not reliably work with NiMHs (AAA) because only worked down to about 1.25 V / cell. Similar things might happen in a DMM.
  • Country: aq
Thank You!
I.e. what alcalines still good for DMMs?
Online Someone
    • send complaints here
Skip over the alkaline cells and go straight for primary lithium batteries (now common as smoke alarm batteries), few people use their meter consistently enough to use much more than the self discharge of the batteries.
  • Country: aq
Can You say what concrete model is good? I hear that Li is flamehazardous
Online Someone
All the long shelf life lithium based 9V batteries appear to be "good", but its hard to know when you need 10 years to test them. Equally the Energiser 9V lithium batteries which have been around long enough to know they work as advertised, may have changed their construction or design since then.
The fire hazard from a 9V lithium is not much different from any other battery, they don't have higher short circuit currents or anything that would make them more likely to cause a fire. But once burning they are much harder to extinguish.
  • Country: aq
And what about NiMH 9V rechargeable batteries?
Offline Circlotron
I would only use one in a good meter that has auto turn off. No fun forgetting to turn it off and wiping out your ten dollar battery in your ten dollar meter.
The following users thanked this post: Someone, 001
Offline wnorcott
  • I like making projects with the ESP32
I have had good luck so far with the EBL 600 mAh rechargeables they last a good long time.  Using it in one of the $20 transistor testers, multimeters and a few other things.  Very close in price now to 9V alkalines too so it's better for me to use the Li-ion.
On very rare occasions, you might notice an odor or see a puff of smoke or sparks vent from your product.
