Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Power/Renewable Energy/EV's
A Boost PFC stage will do fine with a 300VDC input?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: A Boost PFC stage will do fine with a 300VDC input? (Read 1401 times)
Faringdon
Super Contributor
Country:
on:
March 17, 2024, 11:34:34 pm »
A Boost PFC stage will do fine with a 300VDC input.
Whether average current mode, "constant on time mode", or BCM PFC.
LTspice says it will be fine.
Would you agree with this? Our contractor says no , but we think it will be fine.
Logged
'Perfection' is the enemy of 'perfectly satisfactory'
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: A Boost PFC stage will do fine with a 300VDC input?
Reply #1 on:
March 18, 2024, 12:04:55 am »
Many are fine. If the control depends on pulsating mains voltage, or other assumptions about the waveform, that would be a bit of a problem. Some have an integrated X-cap discharge, which is triggered by lack of pulsation; these blow up on DC input.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Faringdon
Faringdon
Super Contributor
Country:
Reply #2 on:
March 19, 2024, 12:33:18 pm »
Thanks for pointing out those cases.
As we know, in a Boost PFC, the outer voltage loop eventually wins out....no matter if vin is half sine or flat DC.
Even the following PFC chip will work with flat DC Input og +300V...
https://www.infineon.com/dgdl/Infineon-ApplicationNote_EVALPFC-300W-ICE3PCS01G-AN-v02_00-EN.pdf?fileId=db3a30433580b37101358a4e00996b86
If you give a flat continuous DC input, then you only use half of the rectifier bridge, so in theory it could overheat. However, bridge rectifiers are as tough as old boots, and the standard Si diodes go lower
in Vf as their temp increases..so they self cool.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
