So I'm running a
15kW bidirectional power supply in a test setup that is running on 3 phase power.
I'd like to be able to use this setup in places where I only have access to 230V single-phase outlets and don't have access to 3-phase power. I'd be ok with running it at lower power in this case, 2kW. I've talked with the supplier and they told me that the device definitely needs 3 phase power in order to operate, even if you use it at lower power ratings.
So I'm looking for a 2kW bidirectional 220V 1-phase <--> 380V 3-phase converter, does anyone know if these exist?
It's part of a setup that I'm mostly using for testing DC-DC converters where I'm supplying 2kW of power with the SM3300 power supply and then I'm sinking this power in the SM15K bidirectional power supply. Both of these devices can be connected to 3 phase power so I'm guessing I could also get away with a ~100W unidirectional 220V 1-phase --> 380V 3-phase converter but this feels tricky.
I was wondering if anyone here has suggestions for me.
