Hi All,
Long time lurker here with a question that is currently stumping me and my team. We're a component test house that was tasked to test output voltage error across a specified temperature range. The datasheet that we have is either crystal clear and we're just special, or it's a bit vague.
Device: AD2700UD
Temperature Drift: 3ppm/°C
Tmin - Tmax: -55°C - 125°C
Test Temperature Range: -30° - 70°C
We decided to calculate the limits at -30°C and 70°C based on the 3ppm/°C and nominal voltage (10V). We then added the error at 25°C: +/- 2.5mV. Does this make sense?
https://www.analog.com/media/en/technical-documentation/data-sheets/AD2700_2701_2702.pdf
